Seats conversion
Old 09-13-2006, 02:45 PM
nicke60gre's Avatar
This modification is for '03 - '04 E60 models and for cars with semi-electric HEATED SEATS ONLY and one pretensioner on each seat (driver - passenger). If your car has not got seat heating from the factory, then this conversion will not be successful and the seats will not work at all.
I cannot guarantee anything so, anyone can do it at his OWN RISK.
AFTER THIS CONVERSION you have to unplug only the black clip-connector from new seat modules and plug it to your OLD SEAT MODULES in any case your car need a CIP UPDATE, so mark your old modules as LEFT and RIGHT and store them.
Black connector
Here is mwaly's post about his conversion from no heated seats with memory and two pretentiones (on each seat)
http://forums.e60.net/index.php?s=&sho...st&p=322210
Requested by vl20sas
First of all disconnect the negative pole off the battery
Let's begin with the driver's seat yellow connector, because vl20sas has a lot of work to do tonight.
The black connector remains as it is (without any modification)
The passenger connector needs the same mod
Unplug this connector here. It's in the trunk's fuse box (rear right)
Open the connector and plug a red wire 4.00 m length in the third place from right to left
That red wire is connected to Pin 2 in the first picture (driver and passenger)
Pin 4 (brown) goes to negative (-) enywhere on the car ie: a screw on car's body
Now make a pair of wires (one white and one yellow) so it will go from one seat to the other around through the glove compartment and the dashboard (about 5.00 meters)
Connect the white wire to pin 1 and the yellow wire to pin 3 from one seat to the other through the glove compartment/dashboard
Now open the glove compartment upper part see pictures below:
Turn - unclip and pull down this big cable connector to connect the yellow wire here and run it to the other seat.
Now you must connect the white wire to the seat heating switch connector on the dasboard.
Open the connector and plug a wire to the third place from left to right and connect it to the white wire.
Connect now all three wires (red2 - yellow3 - white1) to the driver's connector as above in the first picture.
Old 09-13-2006, 02:48 PM
vl20sas's Avatar
My Ride: bmw 530d,2004,500nm,navi profesional.bi-xenon ,adaptive curve light,active sterring,etc...
my problem is whit that 2 whires that need to connect in glove compartiment
Old 09-13-2006, 03:14 PM
vl20sas's Avatar
GOOD WORK,YOU ARE THE MAN!!!
Old 09-14-2006, 09:06 AM
mmwaly's Avatar
Hi Nick,
Many thanks
M. Waly
Old 09-14-2006, 12:20 PM
vl20sas's Avatar
my car
thanks to nicke60gre---the man!
Attached Thumbnails Seats conversion-dsc00385_resize.jpg   Seats conversion-dsc00386_resize.jpg   Seats conversion-dsc00387_resize.jpg   Seats conversion-dsc00388_resize.jpg   Seats conversion-dsc00389_resize.jpg
Seats conversion-dsc00390_resize.jpg   Seats conversion-dsc00391_resize.jpg   Seats conversion-dsc00391_resize.jpg   Seats conversion-dsc00391_resize.jpg   Seats conversion-dsc00392_resize.jpg
Seats conversion-dsc00393_resize.jpg   Seats conversion-dsc00394_resize.jpg   Seats conversion-dsc00395_resize.jpg   Seats conversion-dsc00396_resize.jpg   Seats conversion-dsc00397_resize.jpg
Seats conversion-dsc00398_resize.jpg   Seats conversion-dsc00400_resize.jpg   Seats conversion-dsc00401_resize.jpg   Seats conversion-dsc00402_resize.jpg   Seats conversion-dsc00403_resize.jpg
Seats conversion-dsc00404_resize.jpg   Seats conversion-dsc00405_resize.jpg   Seats conversion-dsc00406_resize.jpg   Seats conversion-dsc00407_resize.jpg   Seats conversion-dsc00408_resize.jpg
Seats conversion-dsc00409_resize.jpg   Seats conversion-dsc00410_resize.jpg   Seats conversion-dsc00411_resize.jpg   Seats conversion-dsc00412_resize.jpg   Seats conversion-dsc00414_resize.jpg
Seats conversion-dsc00415_resize.jpg   Seats conversion-dsc00418_resize.jpg   Seats conversion-dsc00419_resize.jpg   Seats conversion-dsc00420_resize.jpg   Seats conversion-dsc00421_resize.jpg
Seats conversion-dsc00422_resize.jpg   Seats conversion-dsc00423_resize.jpg   Seats conversion-dsc00424_resize.jpg   Seats conversion-dsc00425_resize.jpg   Seats conversion-dsc00426_resize.jpg
Seats conversion-dsc00427_resize.jpg   Seats conversion-dsc00428_resize.jpg   Seats conversion-dsc00429_resize.jpg   Seats conversion-dsc00430_resize.jpg
Old 09-14-2006, 12:47 PM
BetterMakeWay's Avatar
LOL what's with the errors?!?!
brave man! Too brave might i say.
Old 09-14-2006, 12:48 PM
nicke60gre's Avatar
Originally Posted by vl20sas' post='334502' date='Sep 14 2006, 11:20 PM
my car
WOW
Finally you did it. Congrats
Did you erase the errors from memory?
NICE JOB
Old 09-14-2006, 04:39 PM
madoon's Avatar
My Ride: 2005 525i : Alpine White, Steptronic, Black Interior with Amethyst Leather & Popular Grain Brown, 17" 122-Style Rims, Adaptive Bi-Xenon Headlights, Auto Dimming & Folding Mirrors, Advanced A/C, Sports Steering Wheel, Electrically Adjustable Steering Column, Extended Lighting Package, PDC, Sliding Armrest, Bus Navi, Hi-Fi Sound System (MP3 DVDs), CD Changer, Rear Sunshades.. MODS:M-tech front bumper, Painted Grill, Installed Aux-In, Garage Door Opener (Overhead Compartement), ///M Steering wheel, Wood hand brake trim, Wood gear-shift lever. 35% Tint all around.. Got, ACS Roof Spoiler, but not installed..
bravoo...
good job....(both of you)
vl20sas...congrats on your new seats now finish the job and get rid of those errors...
nick....this will be a guide to all e60 seat conversion..
im wondering the red, white and violet wires that go through the glove compartment. are those for the seat heaters?
so if you dont have heated seats on your car and your new seats you skip that step?
Old 09-15-2006, 02:35 AM
vl20sas's Avatar
Originally Posted by madoon' post='334576' date='Sep 14 2006, 07:39 PM
bravoo...
nicke60gre doo all the work,whidaugt him ,i never doo that!
i erase eroors today
that whire are from car bus sitem
Old 09-15-2006, 03:39 AM
ats77's Avatar
My Ride: MY RIDE is DA real .-) HAMANN 5 aka BLACK MAMBA born on 16/06/2005/delivered on 05/08/2005 as following: 530dA (steptronic), Black II (JET), leather Dakota auburn black, mapple trim, head-up display, dynamic drive, active steering, adaptive xenon headlights (auto levelling) with headlight washers, alarm, comfort seats with massage function, advanced A/C, big compartment armrest, aux-in, MP3, Logic 7, Radio PRO, CD in-dash+cd changer, power rear sunshades, rear airbags, park distance control, auto dimming folding mirrors, smoking package, shiny shadow line (individual), fold down rear seats, ski bag, sport suspension, run flats on �116-style� rims (Good Year NCT5+), cup holders, debadged, fire extinguishers, additional permanent power outlet, BMW coat hanger, trunk release button (installed by Hobi), GPS tracking device and a big thx 2 Iceman. Mods done: � Authentic HAMANN FRONT APRON Including ellipsoid fog lights Item-No.: 10 060 110 � Authentic HAMANN REAR SPOILER Item-No.: 10 060 130, � Authentic HAMANN HAMANN ALUMINIUM PEDALS For cars with manual gearbox Item-No.: 80 099 100 81,00 For cars with automatic transmission Item-No.: 80 099 120 � Authentic HAMANN FOOT REST In aluminium For left-hand drive vehicles Item No. : 80 099 122 � Authentic HAMANN HAND-BRAKE LEVER In aluminium For left- and right-hand drive cars Item No. : 80 099 216 � Authentic HAMANN Idrive of alu (sorry this is the only one in the World) but you can have it in carbon fiber , � Authentic HAMANN EXCLUSIVE FLOORMAT SET In black with HAMANN logo in silver For left-hand drive cars Item-No. : 80 060 120 For right-hand drive cars Item-No. : 80 060 � Authentic HAMANN COVER FOR OIL FILLER CAP In aluminium Item-No.: 80 099 117 � Authentic HAMANN SPORT REAR MUFFLER 4 TAILPIPES Sport rear muffler with four round stainless-steel tailpipes ( � 76mm ) Item-No.: 50 060 111 � Authentic HAMANN new add-on for M pack rear with diffusor for quad pipes -AVAILABLE NOW (http://forums.e60.net/index.php?act=ST&f=22&t=30630&st=0#entry332409) � ///M steering wheel w Pegasus logo (this will be also changed to three spoke sports) � ///M pack rear � HAMANN ECU upgrade 265 HP 608 Nm. most improtant: �real and working like a charm forumsbuy real LED tails and PIAA 4700k fogs!!! for HAMANN full front apron you need H3 � CustomAngels, Angel Eyes Brighter than stocks 10X, WHITE & (REd for shows). � Authentic HAMANN LIGHT-ALLOY WHEELS DESIGN EDITION RACE 20" Ultra-light forged 3-pieced light-alloy wheel, Cross-spoke-design,Spider in black, titanium, screwing,polished flange DIMENSIONS : 9.0 J x 20 FA Item No.: 91 207 315 10.5 J x 20 only RA Item No.: 91 207 625 Recommended 20" Complete Wheel Set DESIGN EDITION RACE I went with most aggressive Combination A.10 FA 9.0 J x 20 / RA 10.5 J x 20 with tires: FA 245/30 ZR 20 / RA 285/25 ZR 20 � Authentic HAMANN LOWERING KIT 4 progressive sport springs Lowering by approx. 40 mm FA, 20 mm RA Item-No.: 20 060 125 � Authentic HAMANN TIRE - PRESSURE CHECK SENSOR SYSTEM � Authentic HAMANN SIDE SILLS Item-No.: 10 060 120 � Authentic HAMANN REAL CF ROOF SPOLIER Item-No.: 10 060 235 � Authentic HAMANN AIRBAG SPORT STEERING WHEEL 3-SPOKE Three-spoke design w their SMG paddles (For assembly O.E. airbag in exchange) � Authentic HAMANN sports mirrors (all functions) !!!!!!!!!!!!!!!!!!! and of course !!!!!!!!!!!!!!!!! E60.net Clings Still to do list;-): � Our Hobi's camera system from : ww.switchchange.com). � Individual leather interior (auburn+auburn alcantara)... and drive with sheer drivin' pleasure ... until 2009/2010 F10 comes or E60 possibly a 540d V8 diesel early in 2009 badly juiced!
when you disconnect the cars battery and install something you get errors, after remap you ger errors, aka error messages, all can be deleted easily and no need for dealer when hobi's trunk switch was installed tha AS had to be recalibrated.
ps. Nikos is the man!
Quick Reply: Seats conversion
