restoring your gear stick cover
My Ride: 2004 525i Executive
![restoring your gear stick cover-p7040014.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/83855d1482364887t-restoring-your-gear-stick-cover-p7040014.jpg)
Does your gear stick cover look like this?
I havent seen this on the forum or maybe i have missed it through search,
doesnt hurt to post it again!
This is my first DIY so please dont crucify me if anything goes wrong.
I will do my best to describe the steps
What you need is:
Buffer
Cleaning Chemical
Old CD or plastic pick
Perspex/Plastic polish solution
Cloth
![restoring your gear stick cover-p7040016.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/83856d1482364887t-restoring-your-gear-stick-cover-p7040016.jpg)
![restoring your gear stick cover-p7040017.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/83857d1482364887t-restoring-your-gear-stick-cover-p7040017.jpg)
![restoring your gear stick cover-p7040018.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/83858d1482364887t-restoring-your-gear-stick-cover-p7040018.jpg)
First you basically scratch the matt looking rubber surface off using the CD while the surface is covered with the cleaning chemical.
It will look like poo as it the picture below
![restoring your gear stick cover-p7040019.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/83859d1482364887t-restoring-your-gear-stick-cover-p7040019.jpg)
Then the next step is to buffer it lightly around, then repeat the first step until you reach something like what i have below
![restoring your gear stick cover-p7040020.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/83860d1482364887t-restoring-your-gear-stick-cover-p7040020.jpg)
Again with more elbow grease rubbing off the coating with the cloth damped with the chemical and lightly buffering, you will eventually reach the picture below
![restoring your gear stick cover-p7040021.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/83861d1482364887t-restoring-your-gear-stick-cover-p7040021.jpg)
Make sure everything is buffered evenly so the surface is even and not have bumpy spots
For superior shine, use the polising solution, in my case i used toothpaste
![restoring your gear stick cover-p7040022.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/83862d1482364887t-restoring-your-gear-stick-cover-p7040022.jpg)
Finally, wipe everything with a clean dry cloth and voila!
it doesnt have the matt looking finish as original, but shiny is still better than scratchy!
![restoring your gear stick cover-p7040025.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/83863d1482364887t-restoring-your-gear-stick-cover-p7040025.jpg)
![restoring your gear stick cover-p7040028.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/83864d1482364887t-restoring-your-gear-stick-cover-p7040028.jpg)
Thanks guys for reading, i am interested in seeing all your results or better solutions, so please reply back to this thread!
Great job and good idea, mine isn't scratched yet but if it ever is i will definitely try this. Thanks. BTW, your first DIY went fine, you did great - good pics, good description.
Great recovery!
I was going to suggest that with all the effort just to take that part out, why not just install a new one. But I checked on RealOEM and the replacement part costs $227.![Nono](https://5series.net/forums/images/smilies/imported/nono.gif)
By the way ... how do you remove that part?
Originally Posted by tachyon' post='936148' date='Jul 8 2009, 11:30 AM
Great recovery!
That's a really good idea. Mine isn't scratched, but if it were, I'd definitely do this. Good DIY!
Plus, your interior will smell minty fresh!
Location: Milky Way, Earth, N. America, CA, San Jose, 95136, Latitude N 37� 16.837, Longitude W 121� 50.461
nicely done! great DIY!
