reset rear brake pads
Old 07-10-2006, 12:38 PM
vl20sas's Avatar
My Ride: bmw 530d,2004,500nm,navi profesional.bi-xenon ,adaptive curve light,active sterring,etc...
Hi,
I changed my rear brake pads today (BMW original parts). After that, I tried to reset the service intervall for (was showing (+)1000km to go)
However, after the that it now shows -25000km
i tried to reset that (like oil change) but no resultat!
need help!
thank
Old 07-10-2006, 01:38 PM
Ricracing's Avatar
Questions:
First) the front pads usually need the change, not the rear ones?
Second) did you also change the sensors?
Third) why did you do it yourself
= problems!
Old 07-10-2006, 01:44 PM
vl20sas's Avatar
Originally Posted by Ricracing' post='309066' date='Jul 10 2006, 04:38 PM
Questions:
= problems!
hi,
i replace front and rear pads an discs today (it showing front pads 6000km and rear pads 1000 km)
no error ,nothing!
,i replace that and make 50km to 'format ' brakes,after that i stop the car to reset brakes,i reset front OK,when i tried to reset rear pads ,i-drive show me -25000 km
the sensor is ok,becaus eror was after i replace pads and make 50km
what to doo?
how much cost sensor?is only one sensor?
Old 07-10-2006, 02:09 PM
Ricracing's Avatar
I small add to the answer I send, to vl20sas you, on the personal side.
The dics needs also to be changed every second time you change the pads.
Not now, but the next time.
Kr,
Ricracing
Old 07-10-2006, 02:13 PM
nicke60gre's Avatar
Originally Posted by vl20sas' post='309068' date='Jul 11 2006, 12:44 AM
hi,
no error ,nothing!
what to doo?
Replace your rear sensor (1 piece) and then will automatically be reseted. Don't allow the pads to show 1000 km, when it shows 2000 change the pads, otherwise you need new sensor because during this 1000 km the wire on the sensor has been cutted and when you reset it, it shows -25000 which means destroyed.
Sensor cost 17 Euros, I think it is on the rear right brake caliper.
Nick
Old 07-10-2006, 02:19 PM
vl20sas's Avatar
Nick
thank nick!
i will order sensor tomorow!
Old 07-10-2006, 02:31 PM
nicke60gre's Avatar
Originally Posted by vl20sas' post='309089' date='Jul 11 2006, 01:19 AM
thank nick!
Rear sensor is different vs the front (it has a longer cable) so, order a rear sensor, not just a sensor.
Old 07-10-2006, 02:34 PM
Ricracing's Avatar
Great nicke60gre!
Old 03-29-2007, 11:00 AM
dank530gr's Avatar
I want to thank in public nicke60gre since today I have renewed my rear brake pads and the sensor and managed to delete the alarm message.
The indication was -150 Km and with the first try indicated -25000 Km, with the second and third try no change but with the fourth try I did it and here's one small detail, that maybe help others:
When the "reset?" will appear, you must keep pushing until the -25000 will disappear. Then you must push again for a single time the tacho reset button.
The previous times, I was pushing the tacho reset, at the "reset?" question, the -25000 was disappearing and then i was stopping pushing the tacho reset but it was wrong. I had instantly to push it one more time.
Then everything came buck to normal and the next rear brake change is due after 50000 Km.
Thanks Nick
Old 04-06-2007, 11:18 AM
KREATE's Avatar
about to do my brakes today front and back do you have any pices and what size tools do i need
Quick Reply: reset rear brake pads
