Reset engine Oil counter when not yet due
My Ride: 545i
Hi guys, I'm doing early oil changes and i/m trying to reset the counter. it keeps saying OK and is not asking me to reset. is there another method to reset? thanks in advance!
Hi, just follow the steps in the video and the oil mileage counter will be reset to 15K (I believe), only reset the specific counters that you want.
My Ride: 545i
yup been doing that even before but this time it's not me the option to reset. keeps saying okay and not asking me if i want to reset. thanks might be missing a step.
The only way to do it before its due is with a laptop that has DIS v57 or ISTA/D loaded on to it.
The cluster method will not work if the service is not due (below 1000 miles).
My Ride: 545i
Ahh that's why! thanks blood. still keeps saying "okay" when i'm trying to reset. i did a brake fluid flush when it was due and i was able to reset it through the dashboard procedure, when i try to reset the brakefluid keeps saying okay. i didn't know you can not manually reset if it's not yet due. what's the noramlly value for oil change when it's reset? i can't recall the last time i change the oil, im not using this car much.
