Replacing thermostat?
Old 12-05-2011, 10:06 PM
  #41
BMWDANQ's Avatar
Is this the same procedure to replace the thermostat on a 2005 525i?
Old 12-26-2011, 07:03 PM
  #42
SIC FKR's Avatar
My Ride: Stock for now
I had the same code come on "increased emissions" on my 2004 545i with a little over 84k miles on it. Checked it with my OBDC II code reader and it said it was the thermostat. Picked it up at the dealer for $110. Replacement was straight forward. Refilled with new coolant and the code has not come back. Mine was stuck open too. I would have never guessed that this error code would mean the thermostat was bad. Thanks to this forum for all the great help on these cars. You guys know these cars better than the dealers do.
Old 02-25-2012, 11:36 PM
  #43
Mihainede85's Avatar
My Ride: 530i SMG
How do you change it on a 2004 530i?
Old 02-29-2012, 04:56 PM
  #44
AchtungE60's Avatar
My Ride: E60 530i
"Increased Emissions" is most likely that you are running lean or rich and has to do with gas or air/fuel ratio. have the codes read, jot them down.
As far as a on 04 530 or an 05 525 it is very easy on the M54 engine, same as M52. THis is easily searchable.
Old 03-17-2012, 11:50 AM
  #45
My Ride: 530i SMG
If anyone wants to see pictures of "how to change the thermostat on 530i" pm me with your email address.
Old 01-19-2014, 11:17 AM
  #46
Moksi's Avatar
Had a problem with my thermostat, it was stuck and didn't close. Changed it myself with help of this thread
So thanks ya'll
Old 10-30-2014, 01:17 PM
  #47
SHPD87's Avatar
My Ride: 2005, 545i, sports package, auto trans
Default Did it!
Thanks to all those who posted about this. I was a bit apprehensive to change this myself. I too was getting the same increased emissions warning. My Indy shop guy wanted $350 inc. the parts to change it out. Although not a bad price, I was able to get the T-Stat and coolant for $80 and do the swap in appx an hour. A little tight for the bolt closest to the engine but a swivel head stubby ratchet, various sizes of extensions, and a 10mm socket took care of the job easily.
Once again, thanks to the prior posters who said this was easy and gave me the courage to tackle the job myself.
RobR
06-02-2015 08:31 AM
ETNav382
04-24-2015 07:29 PM
BEZ101
04-15-2015 11:43 AM
BEZ101
04-14-2015 12:40 PM
BEZ101
03-10-2015 06:22 AM
Quick Reply: Replacing thermostat?
