Replacing front stabiliser bar bushes
Changed my brake fluid today, and noticed that my rollbar bushes are shot. (see pic)
![](https://img132.imageshack.us/img132/7012/img1237c.jpg)
Has anyone on here replaced these? Looks quite straightforward from the exploded diagram.
Thoughts/advice anyone?
My Ride: 545i Sport
Engine: N62
- Remove front underbody protection.
![Name: under.jpg
Size: 238.4 KB](https://5series.net/forums/attachments/diy-do-yourself-14/136980d1253477828-replacing-front-stabiliser-bar-bushes-under.jpg)
- Remove stabilizer links on both sides from stabilizer. Replace self-locking nuts with new ones, torque to 65 Nm.
![Name: stab.jpg
Size: 237.4 KB](https://5series.net/forums/attachments/diy-do-yourself-14/136981d1253477911-replacing-front-stabiliser-bar-bushes-stab.jpg)
Grip at torx socket.
- Release 2 self-locking nuts and remove rubber mount from retaining bracket. Replace 2 self-locking nuts with new ones, torque to 30.5 Nm.
![Name: link.jpg
Size: 246.1 KB](https://5series.net/forums/attachments/diy-do-yourself-14/136979d1253477507-replacing-front-stabiliser-bar-bushes-link.jpg)
![Name: BMW.jpg
Size: 68.1 KB](https://5series.net/forums/attachments/diy-do-yourself-14/136978d1253477462-replacing-front-stabiliser-bar-bushes-bmw.jpg)
Keep contact face on rubber mount clean and free from oil and grease.
![Name: under.jpg
![Name: stab.jpg
![Name: link.jpg
![Name: BMW.jpg
My Ride: 545i Sport
Engine: N62
Originally Posted by chris f' post='1012448' date='Sep 20 2009, 02:16 PM
Do i need to replace the nuts? I don't remember seeing that on the TIS.
![Name: BMW_2_.jpg
Size: 581.9 KB](https://5series.net/forums/attachments/diy-do-yourself-14/136983d1253492636-replacing-front-stabiliser-bar-bushes-bmw_2_.jpg)
![Name: BMW.jpg
Size: 515.1 KB](https://5series.net/forums/attachments/diy-do-yourself-14/136982d1253492621-replacing-front-stabiliser-bar-bushes-bmw.jpg)
New self-locking nuts must be used each time components are installed in critical areas.
Spot on, I think the reason I didn't see that is because its not normally needed to remove them, you can get the bush off while that end of the bar is still in place.
Ordered anyway.
Thanks again
Ordered anyway.
Thanks again
jwdominick
05-19-2015 02:50 PM
