Hello,
I have notice on the passenger side trim that is alined with the side of the dashboard ,the triming has come unglued or unravel is there a way to tuck this paneling back in or do you have to replace the entire panel that runs from top off the window down to the dashboard has to be replace. If this is the case how do you remove and replace the panel . I not sure of the name of the panel I think its called Apiller front interior trim. |
found this using the upper right search bar...
http://forums.e60.net/index.php?act=attach...st&id=40532 ^pdf. file for the a-pillar removal... |
Hey thank you for that I feel confident enough to do this my self thank you is just was a matter of finding the clips
