Removing resistors from AUX
Hey guys, I was going to remove the resistors from my AUX cable, and turns out, it wasn't where I expected it to be. By the way, my AUX Input is located in the REAR CENTER CONSOLE, in between the two power outlets. It took me a long time to remove that trim below the AC vent, I was disappointed to see that there were no resistors there. so where is it? Anyone know?
You need to feel your way through the length of the wire going from the jack to the back of the CCC and it will be there somewhere. NOTE only people who have the AUX retrofitted have confirmed that they have the electronic components in their wires, those that have it from the factory may not have it.
This one is factory fitted, so maybe I don't have it, but the sounds that come out isn't the same as my old car with the components removed. Anyways, its ok, I"ll live with it, don't want to removing parts searching for it any ways. thanks bruce!!
Bank$hot530
07-12-2015 04:36 PM
PelicanParts.com
07-09-2015 01:07 PM
