Removing rear spoiler bmw e61
Hi,
My remote key doens't work anymore, and I supects the electronics has moisture. I would like to remove the rear spoiler in my BMW E61.
Doesn't anybody know how I remove the spoiler?
Jan-Peter
Jan-Peter
rear spoiler is attached with four torx'es, which you can access easily if you can open the rear window. I can't, so I have first remove the rear door trim to get the window open manually, and then remove the spoiler. should be quite easy fix.
The_Sauce
06-26-2015 07:40 PM
