removing plastic piece around door pins
Does anyone know how to remove the circular plastic pieces that the door lock pins slide up and down in? My door lock pins rattle and I want to line the inside of the circular plastic pieces. Alternately, does anyone know how to adjust the height of the door pins so they are more flush when they are in the down position?
My Ride: Estoril Blue 440i GC
Model Year: 2017
DoctorJ,
The pin sleeves will come out very easily, but it will take a bit of work to get to that stage.
As you may have guessed, you will have to remove the complete door panel. The sleeves will then push out easily from the bottom. At this stage you may be able to adjust the pin height.
Have a look at these posts regarding trim removal for further help :
http://forums.e60.net/index.php?showtopic=35624
or:
http://forums.e60.net/index.php?showtopic=39246
Mike
or:
Mike
My Ride: G30 M550i
Model Year: 2018
Don't forget to check the following post (and the ones that follow it...)
http://forums.e60.net/index.php?s=&sho...ost&p=23054
UltimatePeter
DIY: Do It Yourself
05-12-2015 08:00 AM
