Reflector headlights to Xenon lci need help
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
Hi guys i have reflector headlights on my pre lci car i want to fit some lci xenon headlights
i have fitted the lci headlights to the car
these new lci head lights are the dynamic xenon ones but for now i just want them to work as xenons without the adaptive function i have coded $522 to the Vo
these are the problems i have
the angel eye rings only come on when the light switch is left in the centre on 0
the angel eyes turn off on all other settings even in auto
the main beam flash only works from the stalk when the light switch is on 0 or on setting 1 not on any other settings
when the low beams work fine on auto and setting 2
when i press the brake peddle when the light switch is on setting 2 the main flasher beam comes on it does this on auto and setting 2
the things that work fine are the
Indicators
Eyebrows
Low Beams
any idea whats wrong
i followed the lci upgrade wiring diagram for the ahl setting
Indicators
Eyebrows
Low Beams
Any one pls need to fix this as the headlights are removed thanks
All sorted now wasnt that hard all lights working as they should so adaptive headlights can be used as normal xenon until you get all the other sensors
There wasnt no wiring help on this forum i looked at wiring diagrams and figured wires out
ucsbwsr
12
07-27-2015 11:20 AM
