Rear jack E60 with AC Hydraulic DK13HLQ
My Ride: 545i
Originally Posted by ObD' post='829415' date='Mar 28 2009, 09:57 PM
There are 2 jack pads on the each side of the car, front and rear, behind the side skirts.
My Ride: E60 530i
Engine: M54
Originally Posted by zerocool' post='829427' date='Mar 28 2009, 10:10 PM
could you kindly share more info in jacking up the car in the front. this would help me alot during maintence works. TIA
My Ride: .
Model Year: .
There is a front jacking point (pad) which is located in the middle of the engine bay. Look under the front of the car, and you will see a rectangular shape black plastic pad in the middle of the car. If you remove the front under cover, you will see this pad located right in the middle of the engine sub-frame. That was the one I used to jack up the front and then put 2 jack stands on each side of the skirts.
Use the center jacking point under the front of car, or the one just behind the wheel (note the red jack in the pic below).
http://forums.e60.net/index.php?s=&sho...st&p=617275
My Ride: E60 530i
Engine: M54
Originally Posted by mrfva' post='829438' date='Mar 28 2009, 10:35 PM
+1 See image below (courtesy of Jeff Fenley).
My Ride: 545i
My Ride: 545i
Do you mind sharing a link to the saddle pads? Thanks!
My Ride: 2008 535i 6MT
I do this to change summer/winter wheels. One lift per side. I put a jackstand on the front jack pad behind the front wheel for safety.
Link to Pelican Parts Saddle
My Ride: 2007 E61 M5, 1989 Z1
Originally Posted by Piloti' post='829399' date='Mar 29 2009, 01:42 AM
First of all 'nice jack' you've got there. They're no longer available in the US. However, I would be careful in that the rating for the DK13 is not very high.
Two more jack pad adapter sources: http://www.ecstuning.com/stage/edpd/pagebu...roductID=251251
and
http://www.reverselogic.us/jackpad.html
I particularly like the last one since it holds itself into the jackpad making it easy to line up.
and
My Ride: 04' 530i Sport/premium/cold wx/PDC/xenon.
Originally Posted by phelix' post='829551' date='Mar 29 2009, 02:28 AM
Why are you concerned about the rating for the DK13 - it's 1300kg and the entire car weighs 1800 so unless you find the centre of mass under the car and lift it at just one point there's a fair bit of margin, no?
I have recently ordered one of the AC Hydraulics jacks, and it has been an ordeal, and expensive, but again, you get what you pay for. This recent flooding of the market by these inferior 'made-in-china' hydraulic jacks, that only last a limited number of lifts, is crazy.
I guess it's the same thinking as the jack stands. You buy 3-ton rated stands for a two-ton car?
