Rear AC VENT Replacement TIS
Hello,
Does anyone happen to have the TIS info on changing the rear vent plastic to wood?
I have seen all of the pictures and steps that people have posted, but I would like the actual TIS for this to get the hours that BMW should charge as well as hours.
Thank you.
Thank you.
My Ride: 640D MSPORT GT
think this is it. dissambly of fittings is not long like for like.easy pull out with correct tools you could easily do this yourself with a plastc credit card or blade sides well supported pull from base and release both top side clips one at a time then down to release lip of aircon vent piece.very easy andyou have nothing to lose if you are changing,
incidentall in uk we dont get most often only get the cubbyhole so maybe you guys that do this would like a swap .cubby hole for accessory power socket type.
incidentall the sckets are solidly fitted on the panel ,but all leads are push fit.
hope that helps
hope that helps
hope that helps
hope that helps
Mike
My Ride: G30 M550i
Model Year: 2018
skipper, I don't recall seeing expected labor hours on TIS documents. I think the only place I've seen it was on specific service bulletins that indicate how many hours to charge for warranty reimbursement from BMW, etc.
Banned
Originally Posted by skipper' post='229743' date='Jan 25 2006, 09:03 PM
Thank you Radioman, however that is part of the full TIS that would give the expected hours and such. I just want that because my dealer is telling me that it would be 1.5 hours and by looking at the posts from people that have done it themselves and the 2 partial TIS docs that show the tool and the removal it looks like it can be done in .5 hours.
Mike
Mike
I'd suggest trying it yourself--it will take less time than you'll spend waiting to drop your car off for service. Check here for more info:
http://forums.e60.net/index.php?showtopic=12430
socale39
09-05-2023 08:30 AM
