radar det
#71
Banned
Originally Posted by Rudy' date='Mar 2 2005, 02:43 PM
In case the newbies missed it, this is still by far the coolest custom V1 install:
http://forums.e60.net/index.php?showtopic=...indpost&p=63545
[snapback]96245[/snapback]
My V1 is hardwired with the main unit located just to the right of the rear view mirror, and I installed the concealed display in front of the (useless) MPG gauge. With this setup, the main unit has perfect line of sight front and rear, without interfering with the driver's sun visor, and doesn't light up, so is not noticeable by police. The concealed display location is perfect since you just have to look down slightly from your normal driving viewpoint, plus the mute button is in easy reach, and police can't see it from behind.
With the arrows in the mirror setup, I don't see what the advantage would be (especially given the additional effort and/or expense), since you still have to look far away from your normal line-of-sight (to where my V1 main unit is located) to see the arrows, and the mute button is also near where my V1 main unit is located--and you don't get the benefit of the concealed display location for viewing the arrows and proximity to the mute button.
Here's a few pix:
#72
My Ride: G30 M550i
Model Year: 2018
Stream, I wasn't trying to say that the mirror install was any better or worse than your setup -- it's just cool as hell!
One thing I learned many, many years ago from a State Trooper friend of mine -- if a cop stops you and knows/sees that you have a detector, there will be no warning issued since that tells them you intended to speed, etc. In other words, if you get instant on'd, your natural instinct is to jam on the brakes to slow down. If the cop sees you do this right when he presses his trigger, he knows you have a detector so the trick is to not hit the brakes if you find yourself getting hit first in a line of cars, etc.
As far as mounting, I always just use the suction cups and cig lighter adapter and, in the rare case where I'm getting pulled over, it only takes a second to remove all evidence of the detector and stash it somewhere out of sight. One time I got pulled over and the cop actually bent down to look up near the headliner to see if I have one. That day, I got a warning since I was able to stash it and he assumed I didn't have one.
I guess that's one plus for the mirror installation. No cop would notice that since it's not very common. For me, I have no need for a permanent install since only State Police in Pennsylvania can use radar. Because of this, I only need my detector if I'm taking a trip on an interstate highway (which isn't a daily thing for me.)
#73
Banned
One thing I learned many, many years ago from a State Trooper friend of mine -- if a cop stops you and knows/sees that you have a detector, there will be no warning issued since that tells them you intended to speed, etc.? In other words, if you get instant on'd, your natural instinct is to jam on the brakes to slow down.? If the cop sees you do this right when he presses his trigger, he knows you have a detector so the trick is to not hit the brakes if you find yourself getting hit first in a line of cars, etc.?
As far as mounting, I always just use the suction cups and cig lighter adapter and, in the rare case where I'm getting pulled over, it only takes a second to remove all evidence of the detector and stash it somewhere out of sight.? One time I got pulled over and the cop actually bent down to look up near the headliner to see if I have one.? That day, I got a warning since I was able to stash it and he assumed I didn't have one.?
I guess that's one plus for the mirror installation.? No cop would notice that since it's not very common.? For me, I have no need for a permanent install since only State Police in Pennsylvania can use radar.? Because of this, I only need my detector if I'm taking a trip on an interstate highway (which isn't a daily thing for me.)
[snapback]96361[/snapback]
Rudy, no offense taken!! Just wanted to add my perspective for those who might be considering the mirror set up.
I know of a few Porsche drivers who bought the mirror with the arrows etched in it, and after spending several hundred dollars realized it didn't really buy them anything (you still have to place the radar detector some place with clear line-of-sight front and rear). And at night, the concealed display is great, since the cop behind you doesn't see any lights on the radar detector (or mirror if you have one!).
Although I've never had to (knock on wood), I agree with removing the radar detector (and concealed display in my set up) if you get pulled over.
#74
#75
The problem I have with stream's set up is the remote location. I really believe the remote is extraneous unless you are putting the V1 in the grill. With you location, stream, I would have to make more of an eye movement than looking at the V1 itself. I have my new V1 in the same location you do. Before I had it on the left where it interfered somewhat with the visor. That was a great location for watching the display -- better than where it is now. I am still adjusting to the new location and may eventually move it back to the left. A ball cap makes a great sun visor.
#76
Banned
[snapback]96681[/snapback]
And as I mentioned before, the other benefit of the concealed display is the main unit is not lit up, so a cop behind you doesn't notice it, especially at night. Plus the mute button is closer than the main unit.
I agree that locating the main unit just to the left of the rear view mirror is a good location, and initially tried that (without the concealed display), but it really interfered with the driver's sun visor operation.
#78
Banned
Here's how I routed the wires from the main V1 unit to the direct-wire power adapter (which is hardwired in the overhead console by the map lights), and to the concealed display in front of the MPG gauge. I started at the overhead console and worked toward the concealed display, but suggest starting at the concealed display, so you know you'll have the perfect amount of wire at that end (I lucked out!).
I used a plastic putty knife from Home Depot to wedge the wire between the interior trim pieces. Push with slow, steady force and you'll end up with no wires showing.
Wedge the wire between the headliner support and roof, then down the a pillar:
Then between a pillar and dash:
Then between wood trim and dash:
And finally above steering column to the concealed display. The pic is with the steering wheel all the way down to show wire (it isn't visible when steering wheel is in driving position):
#80
Thank you very much. Looks like something that will be doing in the near future.
Any thoughts about placing the concealed display to the left next to the A pillar?? I want to see that MPG gauge. J/K
