radar det
#231
Originally Posted by BMWM5NYC' post='820645' date='Mar 18 2009, 05:35 PM
No problem
just for closure, the ground was the issue. The torx bolt on the sunroof motor didn't seem to provide consistant ground, i changed the ground wire to one of the larger (harder to reach) bolts that go into the sunroof cassette, problem solved.
#232
My Ride: 2006 BMW 330ci cab - Jet Black - Black Leather - Premium Pkg - Sport Pkg - Auto - Heated Seats - Navigation - Xenon - Premium Sound - iPod - Bluetooth
I just followed the instructions in this thread, and I cannot get the V1 to power up. I can't tell you how many times I have squeezed the connector with pliers. You can probably see the plier marks on the connector in pic attached. Connector is connected to green/yellow wire. Ground is connected to screw that jksanford used.
Here's the testing I have done. I connected the V1 up to the cigarette lighter & it works just fine. Next, I swapped the cables on the adapter, one going to V1 and the other to the concealed display. Since that didn't change anything, I hooked the cables back as originally hooked up Main to V1 and Accessory to CD.
Here are a couple pics of the wiring. I would really appreciate any advice.
#233
A few more testing items;
- changed the fuse to the connector
- changed the screw that the ground was connected from the one where jksanford used to the harder to reach larger bolt
- used the curly cable designed to go to the cigarette adapter from the connector to the V1 to make sure it wasn't a problem with the cable
None of these item worked.
Still looking for suggestions.
#234
ok had the same issue went nuts, take off the connector, take out the little metal piece inside the blue tap, yes it comes out and squeeze it a little bit. This will make the tap splice through the wire. Just squeezing the blue tap wont do it because the metal piece is too big and the wire to slim. Once you get it powered up, if your V1 has intemediate power or BUZZING once in a while ground it to another bolt or loosen or tighten it. Hope this helps
#235
That was it, and now it works wonderfully. Man, I just love this forum.
#237
#238
Originally Posted by Spyglass' post='852934' date='Apr 20 2009, 01:41 PM
Another tip for that hard to access frame screw used for the earth. Cut the end of your ring type earth wire connector so it becomes an open fork type connector. Then you only have to loosen the frame screw just enough to slide the connector under the screw head.
As stated before the wire you are looking for is in the bundle coming from the rear view mirror, you'll need to cut some of the sticky wrap off the bundle to get to it.
Thanks for the great guide!
-Shane
#239
My Ride: 535ixT � On Order: 2010 E61, Ordered 1/05, Est. Birth 3/09, Est. Delivery 4/09, Carbon Black, Cream Beige Dakota Leather, Steptronic, M-Sport Pkg., Type 135 18
Model Year: 2010
BMW may have changed 2010 E60/61s wiring color codes for the rear view mirror bundle
OK so I go to install my Valentine One, just as I had in my 2006 (See: http://forums.e60.net/index.php?showtopic=708 ).
All was going well until I unwrapped the wire bundle going to the "rear view mirror" (See: Paukend: http://forums.e60.net/index.php?showtopic=708&st=200 Post 223).
I could see NO Green/Yellow wire!
As best I can count, there are ten wires in that bundle as follows:
Many thanks in advance for any and all advice.
Blue ? Gray Line
Blue ? Yellow Line
Brown (2)
Dark Red ? Black Line
Green
Gray ? Yellow Circular Bands
Red ? Gray Stripe
Yellow
Yellow ? Purple Gray Line
Now what do I do? Blue ? Yellow Line
Brown (2)
Green
Red ? Gray Stripe
Yellow
- I suspect that BMW may have changed the color coding on their wiring bundles in cars built starting in March (the 2010 model for the US).
- I don't want to go poking holes in each wire to test for 12 volts ? electricity could leak all over the place.
- Would there be a wiring chart available?
#240
My Ride: 2015 535D M Sport
Blue ? Gray Line
Blue ? Yellow Line
Brown (2)
Green
Red ? Gray Stripe
Yellow
Brown (2)
Green
Red ? Gray Stripe
Yellow
