Predator Ice Install
My Ride: F10 M5
Model Year: 2013
OMG...I was almost done posting and I accidently pressed the back button...
ANYWAYS...here we go again.
![](https://i252.photobucket.com/albums/hh11/r1racer703/1.jpg)
You need a magnetic pick up tool, 8mm socket, small flat head, and torx 30 tool
![](https://i252.photobucket.com/albums/hh11/r1racer703/3-1.jpg)
Remove the torx bolt (2) and remove the 8mm bolt (the small cirlce). You have to look deep down to see it...once unscrewed use magnetic pick up to get bolt out.
![](https://i252.photobucket.com/albums/hh11/r1racer703/4-1.jpg)
Undo the high beam cover...THIS IS VERY IMPORTANT...without taking this off you can't take out headlight.
NOW wiggle the headlight out...you should not need to use force to make it come out.
![](https://i252.photobucket.com/albums/hh11/r1racer703/5-1.jpg)
Once the headlight is out undo the high beam bulb and set aside.
![](https://i252.photobucket.com/albums/hh11/r1racer703/6-1.jpg)
Remove the stock angel eye bulb...all you have to do is give it a good pull apart.
![](https://i252.photobucket.com/albums/hh11/r1racer703/8.jpg)
Now connect the small connector given by Predator Ice and connect with stock wiring. NOTE the colors of the wires. If it doesn't stay together then use the small flat head to adjust the prongs in the connector.
![](https://i252.photobucket.com/albums/hh11/r1racer703/9-1.jpg)
Now put back the high beam bulb back in and zip tie the wires like above.
![](https://i252.photobucket.com/albums/hh11/r1racer703/10.jpg)
Carefully put back the wires in headlight housing. Then wiggle the headlight back in place. NOTE: USE magnetic pick up to screw the 8mm bolt back in then tighten with 8mm socket wrench.
![](https://i252.photobucket.com/albums/hh11/r1racer703/11.jpg)
Right side done!
Right side done!
My Ride: F10 M5
Model Year: 2013
![](https://i252.photobucket.com/albums/hh11/r1racer703/12.jpg)
Left side do the same thing...take out bolts and wiggle the headlight out one you have taken the high beam cover out.
![](https://i252.photobucket.com/albums/hh11/r1racer703/13.jpg)
Undo the high beam bulb and the stock angel eye bulb.
![](https://i252.photobucket.com/albums/hh11/r1racer703/15.jpg)
Install the wires together like the right side...this side I zip tied the connectors together because it wouldn't snug together. Zip tie the wires as well and put in carefully in the headlight housing.
![](https://i252.photobucket.com/albums/hh11/r1racer703/18.jpg)
Both sides DONE.
Thank you and ENJOY!!!
My Ride: F10 M5
Model Year: 2013
Originally Posted by NeRwEEzy' post='542772' date='Mar 10 2008, 11:08 PM
so whens the next time at cha? i went back there twice since we went haha.
My Ride: F10 M5
Model Year: 2013
Originally Posted by alpinewhite' post='542948' date='Mar 11 2008, 09:57 AM
nice.
btw, i ordered fogs using the angelibright thing. is it hard to install? john i think i remember you telling me that you installed yours yourself.
My Ride: F10 M5
Model Year: 2013
