Power Steering Flush
Old 04-28-2020, 09:12 AM
  #41
zbyler's Avatar
My Ride: 09 535i Xdrive, manual, sport pkg
Forgive me digging up an old thread, but I'm looking to change the P/S fluid on my 09 535i Xdrive. Looking through a few threads on here and elsewhere, it seems my car has a different hose routing setup than what I'm seeing.
On the driver side there is a hose coming off the bottom of the reservoir with a quick disconnect, a few inches above the radiator petcock. It seems like this wouldn't drain much fluid since it's only coming from the reservoir.
On the passenger side there is a line down by lower corner of the radiator there is another similar quick disconnect:
The line on the passenger side seems like it would be the right line to disconnect, but I'd like to confirm before pulling it.
Any help is appreciated. Thanks
~Z
Old 05-03-2020, 09:08 AM
  #42
zbyler's Avatar
Well I just said screw it and used a turkey baster to remove the fluid from the reservoir. Filled it with CHF11S, turned the car on and went lock to lock a few times, then removed the fluid again and did a final fill with CHF11S. Used 2 quarts of fluid total.
GroundRat
E39 Discussion
01-29-2020 11:07 PM
JessBeamer
E39 Discussion
10-03-2019 06:51 PM
DBU
05-05-2013 08:48 AM
jonmentor
08-21-2009 07:04 AM
turboawd
05-02-2009 07:34 AM
Quick Reply: Power Steering Flush
