Please Help, amp/ sub install 2005 525i with logic 7 amp
Anyone who could help me, would be greatly appreciated!! I am not a newbie when it comes to car audio, however this is my first BMW, and I'm having a hard time getting an install done. I have the logic 7 system, and I found the amp, checking other forums I found that the wire harness on the top of the amp was where I was supposed to tap in for the loc... I tapped into what I thought were the correct wires, the colors were black/ red, black/ violet and then black/ brown, black/white. I tapped into them, solid connection, than hooked up my power/ ground/ remote/ loc. this is for 2 - 10" bazooka 250 class d tubes. Once I was all hooked up, I started to tune the tubes, and there is hardly any bass at all, and I can hear words through them.... Does anyone know what the correct wire colors are to tap into off the logic 7, or where I went wrong??
In my opinion, this is the best way to go:
https://5series.net/forums/topic/103...9#entry1235319
$85 and all your problems are solved.
incoherent
04-15-2015 04:48 PM
rizwan1377
04-05-2015 05:22 PM
