Paint touch-up recommendations...
My Ride: 2004 545i, sport package, titanium gray, black leather.
Hi guys, I recently purchased both the BMW paint stick set and the touch-up pen(autovisual.com) to repair some minor paint chips and scratches. Which one is recommended? Any suggestions?
My Ride: 2007 530i Alpine White with Navi and Premium PackageIn progress: OEM Mtech kit, H&R Sport Springs, and 19
Hey, I used the set from BMW and got great results. Just clean well and add very, very small amounts and build up. Usually a drop is waaaaaaay too much. good luck.
...............and find out about wet sanding . You can get fantastic results by building up the touch up paint slightly above the clearcoat them wetsanding it down , then adding a drop of clearcoat or just polish it out then wax ,,, good luck
Build it up a little high and then when the paint is tacky take a piece of cloth dipped in Enamel Reducer wrapped around a credit card (so it conforms to any curves in the body) and wipe off the excess. If you do it right (only wipe once and in one direction), you will not have to sand out the spot and it will not have any affect on the original paint.
My Ride: 525d LCI - xenon, tv function,grey dakota leather,titanium silver,244 radial spokes.
My titanium silver car got keyed
The scratch is very thin but runs all the way thru the front door ... which is the best touch-up pen/kit can i order online?
![Bashwall](https://5series.net/forums/images/smilies/imported/bashwall.gif)
My Ride: 08 Porsche 911 c2s, 01 BMW 740il, 05 BMW 525i, 06 Acura TSX navi
BUY THE TOUCH UP KIT FROM BMW CODE 354 ALSO BRINGS CLEAR COAT, INSTEAD OF USING BRUSH FOR THE TOUCH UP USE THE HEAD OF A FIRE MATCH TO TOUCH UP.
Originally Posted by elite_motorsports_BMW' post='623640' date='Jul 14 2008, 02:59 PM
