Need Help from Someone with access to TIS
Old 11-17-2004, 05:48 AM
tedmundson's Avatar
My Ride: 2005 530I Prem Package, Cold Weather, Prem Sound, Bluetooth and Sat.
Ok Some more info on a sirus retro fit.. not sure how this is going to go over with the dealer but from what I found on the TIS .
Sirus has the following connections.
2 MOST Fiber Connections. This connects the receiver in to the MOST BUS, from what i could see in the electrical design there is a MOST bus hub in the trunk. I am pulling my trunk apart tonight to see if this is true.
1 Power Connection. This looks like it can be tapped in to the power panel on the left side of the trunk, there is a fuse spot marked.
1 Ground Connection.
2 Antenna Connections ( I am not sure if the Sharkfin has the antenna built in but worst case you would need to relace the guts for the sharkfin or use a hockey puck)
Will keep everyone advised on my quest..
PakiBeamer
12-09-2016 04:40 AM
bestofthebest
01-05-2016 07:47 PM
subieworx
09-21-2015 01:19 PM
ucsbwsr
09-19-2015 10:58 AM
stylinmike
09-01-2015 04:55 PM
Quick Reply: Need Help from Someone with access to TIS
