Need help with LCI pro nav fitted in pre Lci E60
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
hi guys i have fitted the pro sat nav from a 2008 Lci E60 in to my Pre Lci E60
i needed to clarify few things i had the ccc pre lci sat nav in the car first which was coded with $609 is the new unit codded with the same Sa Code?
also before codding the unit the favorite buttons were working once coded the favorite buttons dont work and the menu for favorite buttons has
disappeared how can i get this back thanks
Yes same SA code but module with new date.
There is a coding switch inside the CCC to enable the buttons.
I changed the production date to 0307 done fa write to cas and lma and it worked and reset with expert profile cappl
550iwa
03-27-2015 06:45 AM
andymax
03-13-2015 10:51 AM
bapeforceone
03-11-2015 04:18 PM
