need help fitted ccc in a lci car 08 coded to car but lci controller not working
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
need help fitted a ccc in a lci car 08 coded to car but lci controller not working
i have tried to change settings in cappl to low and high with out any luck the controller is the original car controller with meuns and other buttons its
a lci controller and the car is a lci too 2008
any idea what could be wrong
My Ride: 07 550i Sports Package
Go to INPA and print the UIF. You either have one of two problems.
1. Your CGATE is not updated to the proper zb#, for LCI controller zb# should be 9185636 not 9185627. If this is your problem you can easily update the cgate with winkfp. you can do it over obd if you don't have OPS, it will take about 30-45 minutes over OBD.
2. If you do have the correct zb# then you need to update the entire CCC. If this is the case you need OPS or an optical connection to update the CCC, it will take about 10 hours and will likely crash if you use OBD.
You also need to code the ZBE to low_with_slopes
bapeforceone
03-11-2015 04:18 PM
