NCSExpert Code Mods
Old 07-25-2012, 12:59 AM
  #601
nunorsilva's Avatar
My Ride: BMW E61
Model Year: 2009
Engine: N47
Hi.
Here's what I've successfully coded on my 2009 E61:
CAS:
VERRIEGELUNGSSCHWELLE Automatic locking doors speed wert_02 (5 km/h)
IHKA:
GEBL_ANZEIGE_AUTO Ventilation speed indicator aktiv
ABWAHL_AC Keep AC off even when turning on the car (except when in AUTO mode) aktiv
UMLUFT_MEMORY Remember last ventilation speed aktiv
KOMBI:
BC_LEERZEILE Remove blank line from BC nicht_aktiv
BC_DIGITAL_V Real Digital speed on BC aktiv
CC_TEMPERATURWARNUNG Temperature warning (high, low ?) aktiv
LMA:
MIND_ANZ_ZYKL_TIPP_BLK Soft touch turn signal
Brake and fog lights blink on force breaking
BFD_1_RL_BL_1_ERSCH_BILD wert_03
BFD_1_RL_BL_2_ERSCH_BILD wert_03
BFD_1_BL_M_ERSCH_BILD wert_03
BFD_1_RL_BL_ERSCH_BILD wert_03
BFD_1_NSL_ERSCH_BILD wert_03
PWM_FL_NSW_FKT_ABBLIEGELI In AUTO mode, fog lights turn on on slow curves and on turn signal wert_02
WL_NSW In AUTO mode, fog lights turn on with welcome lights soft_einschalten
PWM_AN_SL_V_AL_1_34 Angel Eyes intensity wert_03
MASK
AMBANDS Skip AM band aktiv
SHD
REGENSCHLIESSEN With rain sensor on, close sunroof on wiper activation aktiv
REGENSCHLIESSENTILT With rain sensor on, close tilted sunroof on wiper activation aktiv
Regards,
Nuno Silva
Old 07-25-2012, 08:22 PM
  #602
imagine's Avatar
My Ride: 2009 BMW 528i Space Gray | Premium Package | Sports Package | Navigation
Can someone help me code my car? I live in California, SF Bay Area. Another solution would to use a remote application that allows you to control my computer and code it when I set up the software properly? Anyone help please!
Old 07-26-2012, 02:59 PM
  #603
SD5Series's Avatar
My Ride: 2007 ★ Alpine White
Anyone know what the codes are to enable the bluetooth to show the contacts? Mine was working, but when we loaded Rizbel's profile which didn't have bluetooth or Aux-in on his car, it disabled mine whicha already had those options. He was able to get the bluetooth and aux enabled again, but we couldn't still see the contacts on my phone on the idrive. What files need to be fixed? https://5series.net/forums/topic/125...2#entry1459292
Old 07-26-2012, 05:42 PM
  #604
SD5Series's Avatar
how can you default your code settings back to factory settings?
Old 08-11-2012, 01:57 PM
  #605
hollow's Avatar
recode car with ncs expert profile with a blank .man file
or just recode the exact module you require with blank .man file
Old 08-14-2012, 04:04 AM
  #606
C_o_s_m_i_n's Avatar
That is correct. I already did that and it works.
Old 08-14-2012, 09:26 AM
  #607
stecom90's Avatar
It is not advisable to code with a blank .man
you must use backups made ??at the first reading of the module, fsw_psw profile.
or
Expertmode Profile> sg_codieren
Old 08-14-2012, 01:12 PM
  #608
txag_530i's Avatar
That's not a good idea. You should do it as described here: coding-any-ECU-with-the-car-VO-factory-default-settings-using-NCS-expertmode-profile
Old 11-06-2012, 04:34 PM
  #609
AchtungE60's Avatar
My Ride: E60 530i
Why is it not a good idea? These guys at BMW coding are a complete joke. derivatives of derivatives. I've seen posts on there from "mods" that leave me astonished. I've done the above on over 200+ cars. I always do this before I change any options. It's simply a managment file and allows the vehicle to default back the vehicle's original config (VO) so before learning from newbies on the internet maybe you should ask "why not?". I bet you will not even get an intelligent answer.
Old 11-06-2012, 11:47 PM
  #610
BLooD's Avatar
Yup, if you ask any thing over BMW coding you get " I know how to do it but I im not showing you" answer because information is money to them.
Quick Reply: NCSExpert Code Mods
