NCSExpert Code Mods
Old 01-23-2011, 01:47 PM
  #21
NoQuarter's Avatar
Engine: N54
Just bumping this back to top. Several new members joining the coding fun.
As you test and validate settings, update the module changes as shown earlier and repost a current version.
Old 01-25-2011, 05:50 AM
  #22
Ehssan's Avatar
My Ride: Many BMW's
Originally Posted by BLooD
Noquarter the IHKA one only works on the IHKA high, will not function on my basic IHKA.
KGM (sept 2005 onwards)
BEIKLAPPEN_B_KOMFORTSCHL Comfort folding mirrors (Needs SA430)
ASP_BORDSTEIN Passenger mirror kerb function (Needs SA430)
CAPPL
ONLINE_DISABLE_CONTENT Enable BMW online while driving.
(set to content_enable)
VIDEO_DENY_COB Enable video functions while driving
(set to deny_never)
TCU
RINGTONE Changes incoming call ringtone
(3 settings)
In my TCU trc file , I don't have RINGTONE ???
Old 01-25-2011, 09:29 AM
  #23
Ehssan's Avatar
My Ride: Many BMW's
found this on another forums ,, useful for translation ...
File Type: pdf
Old 01-26-2011, 11:44 PM
  #24
d4rkchocolate's Avatar
COMFORT FOLDING MIRRORS FOR PRE 2005/6
TMBT & TMFT
(The modules were installed in the driver and passenger doors untill they moved it to the KGM module in 2005/6)
BEIKLAPPEN_B_KOMFORTSCHL Comfort folding mirrors you need SA430 INTERIOR/OUTSIDE MIRROR WITH AUTO DIP if you are retrofitting folding mirrors
Old 01-29-2011, 01:59 AM
  #25
andy545's Avatar
Model Year: 2005
Engine: 545i
Here is what I've tried (E60 - 09/2004 - with M5 cluster and LCI LM2 lights retrofit):
CAPPL
Cornering lights menu. Corner lights come at low speed turns, with turn signals and in reverse when lights switch is turned to Auto.
VA_CORNERINGLIGHT
aktiv
Result: Partial success. Comes up in idrive-settings-lights and stays ticked but cornering lights don?t work. Ongoing research.
Seat heater display comes up for a few seconds in iDrive when heat button pushed.
VA_SEATCLIMA_SHORTCUT
aktiv
Result: Works.
Alarm sound function when locking/unlocking (adds menu in the idrive ? setting - Lights)
ACOUSTIC
activ
Result: Works.
Activate cycling through the entertainment choices (with steering programmable button) and skip the AM band.
NEXT_SOURCE
activ
AMBANDS
nicht_activ
Result: Works
SMS element in the Communications iDrive
SMS
activ
Result: Partial success. Shows up in idrive ? apparently should show an incoming SMS ? doesn?t on mine.
Notepad element in the iDrive menu
NOTEPAD
activ
Result: Partial success: Shows up in idrive ? apparently should sync notes from your phone ? doesn?t on mine.
KOMBI
Digital speedometer is cluster. Cycle with your BC button.
BC_DIGITAL_V
aktiv
Result: Works.
Show true speed.
BC_DIGITAL_V_KORREKTUR
nicht_activ
Result: Works.
IHKA
Show climate fan speed display via orange LED light around manual speed knob
GEBL_ANZEIGE_AUTO
activ
Result: Works
HUD
Show indicator turn arrows in the HUD
BLINKER_AUSSTATTUNG
aktiv
Result: Works.
LMA
With LM2 use the fog lights as cornering lights
PWM_FL_NSW_FKT_ABBLIEGELI
wert_01 -> wert_02
Result: Did not work on mine.
Install LED bulbs without using resistors and disable cold/warm monitoring and error messages.
Installed LED BAU15S in front turn indicators
KALTUEBERWACHUNG_BLK_V_L
nicht_aktiv
KALTUEBERWACHUNG_BLK_V_R
nicht_aktiv
WARMUEBERWACHUNG_BLK_V_L
nicht_aktiv
WARMUEBERWACHUNG_BLK_V_R
nicht_aktiv
FEHLERMELDUNG_CC_BLK_V_L
nicht_aktiv
FEHLERMELDUNG_CC_BLK_V_R
nicht_aktiv
Result: Works. Similar settings will work on other relevant light elements.
Ongoing Projects:
M view on HUD.
Reported to work on >2006 models and older models with an M5 cluster.
CAPPL
MDrive
activ
HUD_M
activ
HUD
M_SPORT_HUD
activ
Result: Partial success. Mview shows up in HUD idrive setting and stays ticked (when CAPPL elements above are activ as well) ? MHUD stays on for 30secs and reverts back to normal.
When CAPPL elements are nicht_activ, Mview in HUD idrive setting (which is ticked) disappears but MHUD still shows (for 30sec). Ongoing research.
Old 01-29-2011, 06:12 AM
  #26
NoQuarter's Avatar
Engine: N54
Well done Andy - thanks for the summary of your tests!
Old 01-29-2011, 02:43 PM
  #27
BLooD's Avatar
I have since found out that the SMS wont work, it was for the BMW motorola phone and the function is no longer supported as for notepad I can not find anything at all about it.
Old 01-30-2011, 10:37 AM
  #28
andy545's Avatar
Model Year: 2005
Engine: 545i
Check - thanks, might disable them with the next coding session.
Old 02-01-2011, 09:29 AM
  #29
xcntrk's Avatar
My Ride: 2008 550i Sport
This is great input thanks to the community and pioneers who perform all this research
Old 02-01-2011, 05:57 PM
  #30
NoQuarter's Avatar
Engine: N54
CAS:
ER_KEYOUT_AUTOVR (Unlock doors after pressing Stop Button. Driver door only or all doors selected in iDrive preferences)
aktiv
Thanks nomis_nehc!
Quick Reply: NCSExpert Code Mods
