NCS coding for door locks
Engine: N54
I saw in another forum someone listing things you can pay him to change. One of the options was to remove the requirement to pull the door handle twice to get out of the car if it is turned off.
Anyone know which module this would be in?
Engine: N54
Thanks - I'll check it out this evening.
I have one I don't think read anywhere: When I turn on my seat heater, the iDrive screen momentarily switches over to the seat heat distribution screen so you can modify it. Somewhere in CAPPL. I made a few changes at once so not sure exactly which one yet.
There may be a setting in CAPPL, post up what you think the setting is an I can check tonight when I get home if its in CAPPL or the door modules, or Blood or someone may be able to confirm
You can switch to the screen manually I think by holding the idrive to the left on any screen.. but this may be air distribution
My Ride: E60 530i
Engine: M54
https://5series.net/forums/uploads/1...213_695502.pdf
Engine: N54
These settings gave me the seat heater shortcut and heat selection slider in iDrive.
CAPPL:
VA_SEATCLIMA_SHORTCUT
aktiv
VA_SEATHEAT_SLIDER
aktiv
Engine: N54
I didn't get anywhere with the door locks. Nothing in there was too obvious and I didn;t get anywhere with simple translations. That one is going to take some more work.
https://5series.net/forums/topic/106...g/page__st__15
[Seat climate menu in the iDrive]
Control unit: Cappl
VA_AIRVENT_SHORTCUT
nicht_aktiv -> active
VA_SEATHEAT_SLIDER
VA_SEATVENTILATION
SITZHEIZUNG_APP_9
This may help track down the option...
[Comfort Open (2 times to open the remote control) to the driver's window semi]
Control unit: Cappl
K931D_SCHEIBENABSENKUNG
par_gesperrt -> par_frei
Engine: N54
That is a great doc. Did you hust find that on the web or do you have access to others?
