M5 fully electric seats
#32
My Ride: 07' 535D E61... no toys except media pack and vis pack
It wasn't the wiring schematic I am after - but the part number for the actual connector and terminals that it houses so it could be ordered.
I'd prefer not to start soldering to the seat control module if I can help it as any future need to replace would be a nightmare post install.
#33
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
Did any one above get memory seats or full electric seats to work in a semi electric interior car?
Im trying to just power the seats up with out them being in the car on a bench
Or does it need all car wires connected to make move
If so what wires or
Modifications did you do and how?
My interior is full electric memory seats they are going into a 2004 e60 with semi powered seats
My memory seats have their own ecu under the seats
If so what wires or
#34
hi guys! Have a one question: does this seats working without coding after wiring???
Just today done the wiring by myself (with WDS help). Doesnt work... Now after reading this forum, find that had didnt conect two wires.
Anyway main question is: or it will work without codding!
Thank u!
Thank u!
#35
Engine: N54
Thank u!
Thank u!
#36
Did you have a problem getting the switches to operate my passenger switch operates both seats and the drivers switch does not work. also the heat seat switch for the passenger seat operates both heated seats and the drivers heated seat switch does not work. also the memory switches do not work.
HELPPPPPPP!!!!!!!!!!!!!!!!!!
Hi! I have exactly the same problem! How this trouble was solved? By coding? My car will be coded tommorow, so would like to know what i can do more before car coded? Thank u
#39
Oh, thats help me. thank u so much! now doesnt work seats ventilation, seats heating working but the indication lights in central console sometime flashing, stop showing or show good position of seats heating. if asnyone knows what can be with this, will be nice to have some help
Anyway thank u verry much, when i finish this car, will do short explain how i done it.
so do anyone had troubles with seats ventilations? or it suposed to be coded? coz in cant see another way, everything controlled by can bus...
thanx
thanx
#40
Thenk u guys! Everything working, Seat adjustment, heating, memory, backrest width! Later will write how to run the backrest to proper work!
One more time THANK YOU for help!
