A Little Info For Retrofitting Xenon on Fog Light
Old 08-11-2007, 11:00 AM
525iSE's Avatar
Ok, I found out a little something today going to a car garage that installs HID Xenon on these cars with OBCs. Anyways to get rid of the error, you can either use a resistor, on 35W ballasts and bulbs, or you can just use a 50W ballast and 50W bulb or 60W, and not deal with resistors at all. This applies to the fog light, and the halogen high beam or flash as some of you call it. Hope this helps some of you with the fog light xenon-matching retrofit, with actual xenon kit (ballast, igniter, bulb).
Old 08-23-2007, 06:29 AM
subarashi's Avatar
My Ride: 2005 545i E60 Orient Blau Metallic Premium, NAV, Winter Package, Heads Up Display, Logic 7 Audio, AngeliBright Upgrade [White], M5 Body Kit, M Embroidered Seats
Hi! My first post here so bear with me. THanks for the info - my question is simple really. What make/model of bulbs would work best to retrofit the fogs? I would like LEDs or Xenons but do not want to bear with the OBC error. Is the resistor necessary? You suggest that perhaps a 50W bulb would work better as this would not be an issue? I am looking at the fogs only for now! THanks!
Old 08-23-2007, 07:16 AM
525iSE's Avatar
If you're putting blue halogens, nothign is needed, just plug and play. If you're retrofitting xenons with ballast, igniter, etc, get the 50W or 60W ballast and bulbs, it will be much easier than putting resistors. As for make and model, the bulb type is H7 if i remember correctly, and as for the brand, its up to you.
Old 08-23-2007, 09:40 AM
subarashi's Avatar
Thanks for the speedy reply. Which blue halogens do you reccomend? I do not know what the plug type is or what the brands out there are. What did you use for yours?
Old 08-23-2007, 09:45 AM
525iSE's Avatar
Blue halogens are not REAL XENON. No ballast or anything. If you're want to use Blue Halogen, I suggest www.umnitza.com, try the Predator Xenix. For my car, I used a REAL XENON kit.
Old 08-23-2007, 09:57 AM
subarashi's Avatar
I understand. I called PIAA and asked them for their input - they have a HALOGEN Xtreme Light Plus, Part # 19616 that is a 51W=115W bulb that is totally plug and play. The guy I spoke with said there are no issues with the OBC with installation. Here's the link:
http://www.shopatron.com/product/par...er=19616/353.0
My only worry is the OBC - what do you think of this part? How does it compare with the umnitza?
Old 08-23-2007, 10:01 PM
525iSE's Avatar
I already told you the answer. If its HALOGEN, you WONT get OBC ERRORS, no matter what bulb you buy, so no worries there. Secondly, I have never used any blue halogen in my fogs, so I don't know the quality, color, etc. I went directly from stock fog lights to Xenon fogs. As for your question of how PIAA compares with Umnitza, I do not know. I can't help you there. Maybe if you post in the Parts and Accessories forum asking which blue halogen fog to get, then poeple might chime in. This thread just talks about avoiding OBC errors.
Old 09-04-2007, 05:34 PM
subarashi's Avatar
Thanks for the info. I got the PIAA Extreme White HALOGEN Fogs today. Will do the install hopefully tomorrow and post some pix to compare stock vs these ones... stay tuned. Thanks for your help 525!
Old 11-05-2007, 09:23 PM
ITNurse's Avatar
My Ride: 08 535i, Platinum Gray, Sport Pkg
How did the bulbs workout? Did the color match the Xenons color hue? Any issues with the install?
Thanks
Old 11-05-2007, 09:34 PM
GQKaMbiZ's Avatar
what type of resistor is needed for 35w hid kit?
BTW...anyone know what bulb size is for the newer E60 (528/535) low beams??
Thanks
Quick Reply: A Little Info For Retrofitting Xenon on Fog Light
