Left tail ligh Malfunction
I have a 06 530I and my car is giving me the left taillight signal is malfunctioning. I check the light it seem to be ok how do I reset this. Problem Do I have to change all the bulbs even though they are working will that take away the warning message. Anybody help would be appreciated.
My Ride: 2004 530i
Two possible scenarios.
1) The connection at the left taillight signal bulb might be loosen. Open up the panel and check that. Restart the car and see if the error goes away.
2) The bulb might be near the end of its life. You can replace it now. The error should go away.
My Ride: 2004 530i
Originally Posted by kduff70' post='955449' date='Jul 27 2009, 10:26 AM
Thank you I'll try that so when the the bulbs are near the end of it life the lamp Indicator will come on?
Thank you for all your input I replace the bulbs and malfunction indicator went away. What was interesting to me was the bulbs had not burn out but when I took out the bulb you could see the it had just start to blacken the bulbs so it was on its way out once again thank you all for your advice
Ticomystico@gmail.com
07-10-2015 05:19 AM
