LCI instrument cluster (Kombi) in Pre LCI car
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
Delete thread
Delete thread
Check to make sure your daten files are correct. The mileage is no longer stored in EEPROM with the intro of E65 then carried over to E60 then to E90. It is stored in CAS/LM. This info is being transmitted to your KOMBI
I will look at the files but can you give the UIF info please of both your old cluster and this one? Trace file isn't going to tell anything.
Here I've made changes to the LCI cluster trace after comparing them. This is the changed file.
However, these values below are on the LCI but were not on your original. So I did not change them. What I would do is first get the ZBNUMBER for each on the UIF. I would flash the unit and add your VIN. Use WINKFP. Then I would encode it individually with a blank managment using NCS and the lastest DATEN. Then just process the entire vehicle. Now after that if there are still issues then you can look at the stuff below. A lot easier than a vehicle that had EEPROM eh?
ACC_ALIVE_ZAEHLER_1
aktiv
ACC_AUSSTATTUNG_1
wert_03
ACC_CSUM_MONITOR_1
aktiv
ACC_E60_ALIVE_ZAEHLER
nicht_aktiv
ACC_E60_CSUM_MONITOR
nicht_aktiv
ACC_E60_ID_MONITOR
nicht_aktiv
ACC_ID_MONITOR_1
aktiv
AHM_APPL_MONITOR
nicht_aktiv
AIRBAG_ALIVE_ZAEHLER
aktiv
AIRBAG_ID_MONITOR
aktiv
CAS_APPL_MONITOR
aktiv
CC_EHH_ANZ_MIN_TIME
wert_01
EHC_APPL_MONITOR
nicht_aktiv
LM_APPL_MONITOR
aktiv
RDC_APPL_MONITOR
nicht_aktiv
TANK_EINGANG
wert_01
TANK_KL_STEIGUNG
wert_01
TEL_ALIVE_ZAEHLER
aktiv
TEL_ID_MONITOR
aktiv
TLC_ALIVE_ZAEHLER
nicht_aktiv
TLC_ENABLE
nicht_aktiv
TLC_ID_MONITOR
nicht_aktiv
VDM_ALIVE_ZAEHLER
nicht_aktiv
VDM_ID_MONITOR
nicht_aktiv
SCHALT_HINW_ID_MONITOR
nicht_aktiv
SCHALT_PKT_BC
nicht_aktiv
SCHALT_PKT_DAUERHAFT
nicht_aktiv
ACC_ANFAHR_GONG
nicht_aktiv
ACC_APPL_MONITOR
aktiv
ACC_MODE_ANZEIGE
aktiv
DZM_DAEMPFUNG
aktiv
DZM_DISP_RPM
wert_01
DISP_ENGDAT_ALIVE_ZAEHLER
nicht_aktiv
DISP_ENGDAT_ID_MONITOR
nicht_aktiv
TELEX_STATUS_SC
wert_02
TLC_SYMBOLIK
wert_01
ACC_E60_APPL_MONITOR
nicht_aktiv
SCHALT_HINW_ALIVE_MONITOR
nicht_aktiv
SCHALT_HINW_CSUM_MONITOR
nicht_aktiv
A3C6_APPL_MONITOR
aktiv
A569_APPL_MONITOR_UEP
aktiv
DZM_UMRECHNUNG
wert_02
TORQUE_3_ID_MONITOR
aktiv
CC_ID_AKTIV_7
aktiv_01
DISP_ENGDAT_SIG_MONITOR
nicht_aktiv
TORQUE_ENGDAT_SIG_MONITOR
aktiv
BC_EFF_GESCHW_BEI_KL_R
nicht_aktiv
CAN_OEL_DIENST_ENA
aktiv
ACC_ALIVE_ZAEHLER_1
aktiv
ACC_AUSSTATTUNG_1
wert_03
ACC_CSUM_MONITOR_1
aktiv
nicht_aktiv
nicht_aktiv
ACC_E60_ID_MONITOR
nicht_aktiv
ACC_ID_MONITOR_1
aktiv
AHM_APPL_MONITOR
nicht_aktiv
aktiv
AIRBAG_ID_MONITOR
aktiv
CAS_APPL_MONITOR
aktiv
CC_EHH_ANZ_MIN_TIME
wert_01
EHC_APPL_MONITOR
nicht_aktiv
LM_APPL_MONITOR
aktiv
RDC_APPL_MONITOR
nicht_aktiv
TANK_EINGANG
wert_01
TANK_KL_STEIGUNG
wert_01
TEL_ALIVE_ZAEHLER
aktiv
TEL_ID_MONITOR
aktiv
TLC_ALIVE_ZAEHLER
nicht_aktiv
TLC_ENABLE
nicht_aktiv
TLC_ID_MONITOR
nicht_aktiv
VDM_ALIVE_ZAEHLER
nicht_aktiv
VDM_ID_MONITOR
nicht_aktiv
nicht_aktiv
SCHALT_PKT_BC
nicht_aktiv
nicht_aktiv
ACC_ANFAHR_GONG
nicht_aktiv
ACC_APPL_MONITOR
aktiv
ACC_MODE_ANZEIGE
aktiv
DZM_DAEMPFUNG
aktiv
DZM_DISP_RPM
wert_01
nicht_aktiv
nicht_aktiv
TELEX_STATUS_SC
wert_02
TLC_SYMBOLIK
wert_01
nicht_aktiv
nicht_aktiv
nicht_aktiv
A3C6_APPL_MONITOR
aktiv
aktiv
DZM_UMRECHNUNG
wert_02
TORQUE_3_ID_MONITOR
aktiv
CC_ID_AKTIV_7
aktiv_01
nicht_aktiv
aktiv
nicht_aktiv
CAN_OEL_DIENST_ENA
aktiv
What were you connecting to it with? And what were you trying to write to it with? An E92 and an E60 are two different filesystems and therefore are two different data sets.
I never heard of that cable sorry.
Anyway I see you were able to access it since you got the trace files. Go to INPA and give the UIF. As far as writing to it. It's something easy to do. I don't know if you're up for flashing or not though.
Its the best cable that normally costs $90 or so
I done loads of coding for a few years with out any issues
I dont mind updating the software of thats what i have to do Blood loves across the river from me can always go see him as hes also interested in doing this mod
How long does flashing take for a kombi
I have not had the chance to get the uif info for the new one as not had chance to swap it ober again will do this tomorrow
Just finshed fitting a 2009 sport wheel into my pre lci car
Can`t change the VIN number in these kombis, the VIN is write protected. I just flashed my LCI combi and the VIN didnt change.
