KyleB's 6HP19 service thread
Old 03-15-2015, 06:20 AM
  #81
a10warlord's Avatar
My Ride: BMW 525 E60 2004
Today I cahnge My trans fluid, filter and mechatronic sealing adapter on my Zf6HP19Z and reset Error memorry, my gear shifting become very smooth but trunsmission mulfunctionc code 4F81, 4F8 and 4F86 is still here (((( when i push my accelerator hard my rmp slips and trunsmission mulfunction message apprears.... Can anyone Help me pleeeeeaas (((((
Old 03-15-2015, 08:24 AM
  #82
KyleB's Avatar
My Ride: 530i
Engine: M54
those are all 'ratio monitoring' codes, i.e. EGS is detecting slip in multiple clutch packs. how many miles are on your car? In the meantime, don't press your accelerator 'hard', you will send your transmission to the scrap yard.
Either your clutches are genuinely worn (less likely) or your valve body (Mechatronic) is malfunctioning.
Did you read through the first post in this thread in its entirety?
Old 03-15-2015, 11:14 AM
  #83
a10warlord's Avatar
My car have 199 000 KM...... i read first post and i change my fluid accordint to this instruction of course .... is it possiable to repair it myself with Sonnax ZIP Kit???
Old 03-16-2015, 02:24 AM
  #84
KyleB's Avatar
My Ride: 530i
Engine: M54
Yes, although I'd suspect worn solenoids before I dismantled the valve body and replaced accumulators, etc.
Old 03-18-2015, 10:33 AM
  #85
a10warlord's Avatar
can vacuum leakage in VB couse solenoid trouble codes in TCU??
Old 03-18-2015, 05:41 PM
  #86
KyleB's Avatar
My Ride: 530i
Engine: M54
ANYTHING that is preventing proper fluid pressures and travel through the valve body can cause fault codes in EGS.
Old 04-12-2015, 04:04 PM
  #87
pcy
pcy's Avatar
The mechatronics sleeve just started leaking on my '06 530i. So, I replaced it along with the bridge seal as well as the 4 tubular seals.
After putting back everything, I filled the trans with 5 qts of fluid. It wasn't enough (around 6 to 7 qts of fluid came out). So, I am short by about 1.5 qts. I will get another container tomorrow.
I am getting the "Trans Fault - Gear can be engaged without depressing brake"
4E87 - shiflock
P0982.
I am thinking of dropping the pan again tomorrow and rechecking the sleeve connection as well as the gear selector cable connection to the mechatronics.
Any suggestions?
Old 04-13-2015, 11:22 AM
  #88
pcy
pcy's Avatar
Update:
Apparently, I didn't insert the sleeve far enough. I dropped the pan, removed the sleeve and reinserted with some persuation with a wooden dowel, it went in further than I had inserted last time around. I think it's because of the new o-rings on the sleeve, it didn't go in easily.
Anyway, I put everything back, filled the fluid, no more errors. Trans is engaging in DS mode. It's all good now.
Old 04-13-2015, 11:43 AM
  #89
KyleB's Avatar
My Ride: 530i
Engine: M54
Originally Posted by pcy
...as well as the gear selector cable connection to the mechatronics.
yep, that's what I'd do.
I didn't have mine set properly when I first put my car back together. I realized my error before putting the car back on the road, so I wasn't getting any fault codes. Hopefully that's all it is for you. good luck.
Old 04-13-2015, 03:27 PM
  #90
KyleB's Avatar
My Ride: 530i
Engine: M54
just saw your other post, glad you got it sorted.
Quick Reply: KyleB's 6HP19 service thread
