Kidney Grill Swap
I know this topic has been beaten like a dead horse but recently receive a set of Matte Black Kidney Grills for my '07 E60 5-Series. In any event wanted to find out if anyone had clear instructions on how to do the swap seems fairly easy from the steps i have seen...such as removal of top weather strip, 5 Tex Screws, top clips on grill....unfortunately, only problem im running into is that there are (2) more clips on the sides of the grill along with the bottoms that are giving me a hard time. Any Info on the swap is greatly appreciated.
Trippy718@aol.com
Trippy718@aol.com
You just need to compress the tabs gently. You can use a screw driver with some tape on the tip for extra reach for the side ones. The bottom should come up easily once the tension is off the top. Just do it super slow or you will bust a tab. Trust me, unfortunately I know this for a fact.
Location: Milky Way, Earth, N. America, CA, San Jose, 95136, Latitude N 37� 16.837, Longitude W 121� 50.461
This is from RPi's website for installing the air scoop, but it's also a great step by step with pics on removing the kidney grilles. I hope this helps!
http://www.raceprecision.com/forums/viewto...hp?f=7&t=17
umichchris
09-10-2015 12:54 PM
