5Series.net - Forums
-   DIY: Do It Yourself (https://5series.net/forums/diy-do-yourself-14/)
-   -   key fob in glove box (https://5series.net/forums/diy-do-yourself-14/key-fob-glove-box-137901/)
user 007972497204 Apr 22, 2014 06:34 AM
Hi.
I just found what looks like a spare key fob clipped into the back of the glove box on my E60 535d M sport, what is it? :eek:
txag_530i May 1, 2014 01:50 PM
A picture is worth a thousand words.
twidge May 4, 2014 07:23 PM
its for your plastic valet key to slide into in case you don't have your standard keyfob. That way you can still stick the key into the ignition and start the car.
user 007972497204 May 7, 2014 12:41 AM
Not sure I have a plastic valet key, not found that yet? Will look in manuals that were with it. Thanks.
Gee_115 May 14, 2014 10:26 AM
Probably is your spare key. There is a charging port in your glove box which is supposed to be used to keep your spare key fully charged.
user 007972497204 May 15, 2014 08:41 AM
can't find any plastic key, it is defo not my spare fob, or where it charges, there is no pwer to the case it sits in.
E60Cruisin' May 25, 2014 06:16 PM
It is definitely a spare key it is referred to as key number 3 as you should have to two fobs that came with your car. It's written in your manual and no it does not charge it is simply a "holster" if you will for the spare key which could also be a valet key.
wcr3d May 26, 2014 11:30 PM
Here is a link to what I think you're referring to. It takes both parts to function. The car has to be optioned with it or they can be purchased afterwards.
BMW 3 Series 2006-2011 E90 BMW Valet Key
Excuse the name of the link, as you can see near the bottom of the page it applies to a number of different series.
user 007972497204 May 27, 2014 07:35 AM
that's it, just got to find the actual plastic key now!
