iPod Hardwire Install
#22
Banned
Originally Posted by my530i' post='216189' date='Dec 27 2005, 10:13 PM
the only thing you can control is the volume (with the steering wheel buttons or control on dash).
#23
Stream, is the Aux-input happy with a line input rather than an amplified signal? I assumed that as it was probably meant for devices that only had a headphone jack, BMW was expecting an amplified signal?
I am using the Belkin at the moment and the sound quality is not good, nor is the volume. If I don't need an inline amplifier I'll take it out!! (Won't the volume go down even more?)
Incidentally, I think Dension are doing some kit that uses their cradle but gives an aux output to plug straight into the aux input!
#24
Banned
I originally had the Belkin and the sound quality was bad so I returned it and got the Monster. Do you have the volume wheel on the Belkin on max?
#25
I did have the voulme on mid, then put it to max (to get more volume) and the quality was even worse and serious electronic interference so I turned it down to mid again.
I guess the line input detects the voltage and adjusts accordingly! I think I'll get the monster lead! Or see whether the Dension option is available yet
#26
help,
i cannot seem to post my picture. But there is a wire just at the bottom of the right yellow circle in the above picture...it has a small black box about 1.5 x.5x.5 cm without a wire connection to it...what is this for?
after going through this set up the ipod works great but my back seat heater on the right does not work?
any help would be appreciated!
thanks
#27
Banned
Originally Posted by iiwii' post='241191' date='Feb 16 2006, 08:16 AM
help,
thanks
thanks
Phone_cradle_install.pdf
For the seat heater, you may have caused the wires that connect to the switch in that panel to come loose--try reconnecting them.
#29
Banned
Originally Posted by iiwii' post='241212' date='Feb 16 2006, 08:52 AM
thanks for the prompt reply!!!
hey...any thoughts on the heated seats?
On the seats, as I said above, you may have caused the wires that connect to the switch in that panel to come loose--have you tried reconnecting them?
#30
Yes, i did push in the housing for the heated seat buttons...no change...would you have any schematics on the housing for the heated seats? I am kind of afraid to disconnect anything. :'(
thanks again!
thanks again!
