internal trim
Old Mar 17, 2006 | 01:31 PM
stuart harmes's Avatar
My Ride: 525ise, Dec 2003, Silver Grey, Black Dakota Leather, Bluetooth, 18'' Runflats, Folding mirrors, Automatic/man box,parking sensers front/rear,latest addition 645ci black saphire, with everthing on, nothing it does not have.
i am running some cables from front armrest to the glove box.Anyone got any suggestions on how to remove the carpet trim
Old Mar 25, 2006 | 03:43 PM
chrishei's Avatar
bump im interested aswell
Old Mar 27, 2006 | 04:43 AM
Justin's Avatar
My Ride: 2004 E60 Bi-Fuel Business Navigation Park distance control Sunroof extended airco with armrest 18" M5 rims with Runflats xbox with 2 headrests LCD front LCD video enabled Detachable towbar Alarm anti-blind rearview mirror Adaptive Xenon Bluetooth carkit Garage door opener integrated Headlight cleaning system Seat heating front
This is a possibility:
On the back of the armrest , there are 2 rear seat units mounted: one heater/cooler vertilation unit, and in my case an small box to put some stuff in. To remove the lower box, put 2 credit card like cards on the left and on the right side of this box, and insert them, now both mounitng clips will be released, and the box can be removed.
On the inside of the armrest, you see two nuts, unscrew these to loosen the armrest.
Now remove the rear seat by pulling on part where you sit on, you can just pull it off its not really fixed.
Remove the glovebox by unscrewing 6 screws on top, and 4 under at the foot compartment.
remove the plastic trim at the rearseat door, by just pulling it with your hands, do this also at the front-door, There is also a small plastic trim under the glovebox, that needs to be removed by pulling. Now you can place your cable from the armrest -> under the carpet -> rearseat carpet, -> side of the doors carpet -> glovebox.
Another possibility, is to lift the armrest as described above, and shove the cable under the console at the side to the glove-box directly, but this depends on how big your cable is its has to be thin for this.
Justin
Old Mar 27, 2006 | 04:46 AM
needforspeed's Avatar
Check out this post by Stream for a really simple route from the armrest to the glovebox.
http://forums.e60.net/index.php?showtopic=12430
I did the same thing with my ipod cable and it was really easy.
Old Mar 27, 2006 | 05:05 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
This may help too...
http://forums.e60.net/index.php?s=&showtop...indpost&p=46570
Old Mar 27, 2006 | 05:07 AM
Originally Posted by Rudy' post='260620' date='Mar 27 2006, 03:05 PM
rudy - how long have you been a girl ?
Old Mar 27, 2006 | 05:27 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Are you trying to pick me up?
Old Mar 27, 2006 | 05:41 AM
based on your avatar - ermmm no - let's just be friends.
Old Mar 27, 2006 | 05:51 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
I look much better once the novocaine wears off...
Old Mar 27, 2006 | 06:12 AM
I'll need something stronger than novocaine
Kaane
Mar 15, 2022 05:16 AM
Vman33
Mar 14, 2022 04:43 AM
CHRGRS_BMW
38
Sep 1, 2016 09:39 AM
DetailersDomain
Detailing Forum
Sep 22, 2015 03:59 PM
jimmychef
Jul 7, 2015 05:17 PM
