Hi does anyone have DIY for all interior wood trim (including door handles?), I triyng to install my carbon fiber interior! Thanks in advance!!!
P.S. I'll post some pics after installation is done. |
Have a look at the following thread which is my contribution. there are others around.
You should find out what you need to know from the thread. http://forums.e60.net/index.php?showtopic=35624&hl Mike |
Originally Posted by imposss' post='520095' date='Jan 19 2008, 05:50 PM
Thanks but I need whole trim I don't know how to remove center console trim (where iDrive is) Thanks
http://forums.e60.net/index.php?s=&sho...ost&p=22525 Keep in mind that I think the goal of my original posts was to help someone remove the entire CCC computer system so if you're only removing the wood trim, you probably don't have to disconnect the battery and you can obviously stop following the steps when it gets to the part about removing the CCC module, etc. (Also, unfortunately, each step is attached to it's own reply because back when I posted these, the board software wouldn't allow multiple attachments in a single post.) |
yeah but can you guys give an idea where will be the clips for the are where the iDrive is , to remove that whole part up to the ashtray? I am a bit confused.
P.S. I'll post some pics after installation is done. As i can see you are from montreal, i live in montreal too. Are you going to sell your wood trim ? If yes, i will buy it. Let me know, PM me if you want also. Thanks |
