Installing Amp/Sub in the trunk
Hello Guys,
I have installed the Sub/ Amp in the trunk, using the instructions below.
Left + Black/Red
Left - Black/Violet
Right + Black/White
Right - Black/Brown
On/Off White/Violet
However, the base was not even 1/4 of what it used to be in my E46 with the same amp and sub. I did some homework, especially on the adapter that I have in the middle of my connections to factory amp, and new amp. It seems like it is a signal reducer (picture attached). Is it possible that I am taking the input before the amp (however, I think its after, you can see the pictures) and reducing it further before it goes into the after market amp? If its not, then where could have I gone wrong?
I am also not sure if my remote is working properly or not. Coz, I can see the amp's light on, even when the sound system/ car is off.
Is it better to take this signal reducer out, or connect to factory system after the amp?
Will really appreciate your feedback.
Left + Black/Red
Left - Black/Violet
Right + Black/White
Right - Black/Brown
On/Off White/Violet
I remember reading that there is already a low level input to the amp. So with that said, It looks like you're taking the low level with a line-level converter and putting them to low levels and then feeding amp with RCA. I would just look at your amps high level input and hook up to the amp that way. that's what I did and it worked fine. R +/- and L+/- and then extend them to the amp's input and connect it. You may or may not need the ground wire on the high-level input.
This is how I did it and it worked fine. But be sure to solder everything and use shrink loom as I see you're using electrical tape and I have to frown upon this. I hope this is just thrown in to test before you hook everything up and neatly run/hide wires.
I actually just did it a little while ago.. the exact same thing that you said
Not sure about the ground wire (I never had it)... however; the remote is working fine (checked it).
Yes, I have to get out of the habit of using electrical tape and start using proper connectors. I didnt have them, so I actually redid it the same way :$. Whats the downside? Isnt that electrical tape meant to be used for this purpose?
Thanks again
So all is working now?
Don't worry about ground if your amp doesn't have...all are different.
Electrical tape is OK for testing but really you should slip a few pieces of looming of the wire, connect it up and solder it together, and put a the loom over it and heat and then repeat for the second one so you have two shieldings. Electrical tape doesn't stick well when hot (this is summer). Besides me having OCD it's just best practice to keep things professional.
hello everyone, i really need help on how to find the actual wires to connect an after market amp, my car is a e60 2004 model with no factory amp or subs. im pretty sure it is the standard sound system with just 4 speakers. can anyone help please![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
You can also look in the boot to see if an amp is physically present. If not then at least the plug is there. It would be best to physically check. That way you may get more accurate help.
My Ride: 530i
Thanks man...
. Took out the RCA and converter, and connected it to Amps high level input.
Thanks again![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
Thanks again
Knubblo
10-11-2008 10:10 AM
