iDrive skips when ZBE set to low
Hi everyone, hope someone can help.
I have programmed over 100 cars but have run into a strange problem I have never had before. I programmed ZBE to LOW in CAPPL (was set to high) to disable the tension when scrolling in a 2005 E60. Have done this multiple times in other cars without any issue's. But in this car after having set it to low, it skips choices. So when you scroll through your phone book or radio stations for instance, it always skips about 3 selections. This also happen when I set ZBE to LOW_WITH_SLOPES.
Any idea's? Is there a setting that skips selections somewhere?
leceur,
if you have some iDrive programming experience, I could benefit from your advice. My iDrive is skipping like crazy but it goes right to the last choice on the screen with just one click. I have upgraded my CCC to CiC but I am still using the CCC iDrive controller. Can you advise which codes I would need to change to slow the iDrive down?
Thanks for your help!
My Ride: BMW 550i
leceur,
with old controller you need add +ZBEP to FA then code it
Awest91
09-17-2022 11:05 PM
rackhacker9275
26
04-16-2015 08:13 AM
incoherent
04-15-2015 04:48 PM
macantley
03-31-2015 03:44 PM
