Idler pulley torque spec
There are a few strong opinions on the forum for the N52k idler pulley torque setting.
A few say its 33 ft lbs. I looked it up in the TIS manual, and if I'm reading it correctly, it says 59 ft lbs. Is this a mis-print below?https://cimg7.ibsrv.net/gimg/5series...b77f759fe6.jpg |
Yes you are correct, except that is 59 lbs-ft, not ft-lbs.
