How to replace O2 (Oxygen) sensors on a 545i
Old 02-08-2013, 12:04 PM
paran's Avatar
My Ride: 2005 545i Sport
Originally Posted by Stephen Max
Hmmm. It only took about 5 mins to move the steering tube out of the way and another 5 to get it back on tight.
You mean the black, flexible tube, about 1" in diameter, cinched in place with a plastic strap?
I released that without question, and it freed up some space, but not enough for a hand to squeeze in (at least not mine); or do you mean the steering column shaft?
I avoided loosening any bolts (especially on the steering colum shaft) as there was no way to correctly torque them. I am frustrated that I wasn't able to properly torque the O2 sensor but there was no way to get my torque wrench into a proper position to register an accurate reading.
Old 04-29-2017, 02:32 PM
f1peterc's Avatar
Folks,
I replace the pre-cat oxygen sensors on my 2005 545i SMG. It was a relatively easy job.
All I had to do was to remove the plastic shielding to access the connectors, and the plastic shielding behind the front wheels to access the sensors, nothing else.
socale39
09-05-2023 08:30 AM
tis66
05-18-2021 08:59 PM
coreybunz
05-01-2015 07:24 AM
Adam1v
04-05-2015 11:40 PM
08-12-2003 11:41 AM
Quick Reply: How to replace O2 (Oxygen) sensors on a 545i
