How to replace DRL bulb on pre-lci e60?
Old 12-08-2010, 06:51 AM
seahawk's Avatar
Hi,
Been search the forum for DIY on replacing the OEM DRL light bulb on pre-lci e60 and can't seem to get any luck of finding it. Please help much appreciated.
Thanks
seahawk
2006 550i
Old 12-10-2010, 10:17 AM
seahawk's Avatar
no one knows how?
Old 12-10-2010, 11:40 AM
chhay24's Avatar
if you got a small hand you could reach in and try to change it.
the easiest way (for me) is taking the headlight out and change the bulb.
If you do a search on taking the headlight out, i'm sure there's some.
you can even youtube it
hope it helps
Old 12-13-2010, 09:14 AM
seahawk's Avatar
Thanks for the info, too bad someone did not do a DIY on just replacing the bulb without removing the complete headlight assembly.
seahawk
Old 12-15-2010, 03:28 PM
balbs's Avatar
My Ride: BMW
seahawk
That's the problem though. As what chhay24 says, if you have small hands you "might" be able to do it. It's a real tight fit. I have small hands and it's still a pain in the a$$ that it was easer for me to take the whole thing out. Most DIYs involve taking the assembly out because it's just easier that way.
Old 12-15-2010, 03:34 PM
luigi524td's Avatar
Originally Posted by balbs
That's the problem though. As what chhay24 says, if you have small hands you "might" be able to do it. It's a real tight fit. I have small hands and it's still a pain in the a$ that it was easer for me to take the whole thing out. Most DIYs involve taking the assembly out because it's just easier that way.
+1 Removing the headlight assembly takes 5 minutes and makes bulb changing 100 times easier.
Old 12-15-2010, 03:47 PM
balbs's Avatar
My Ride: BMW
Video:
***Ha Ha, just noticed the guy had those nasty chrome surrounds on the headlights!**
Removal PDF:
http://www.bimmian.com/elements/page...LHU/LHU604.pdf
socale39
09-05-2023 08:30 AM
Tsoup
15
12-20-2021 11:14 AM
Kasmo
05-07-2019 03:30 AM
BYS2
03-24-2015 03:13 AM
ZeZe
10-15-2003 12:58 PM
Quick Reply: How to replace DRL bulb on pre-lci e60?
