1 Attachment(s)
Pasted from Ebay :thumbsup:
Take the traditional blue & white BMW emblem. Step 1 -- To remove the existing emblem. we use a pasteboard as a fulcrum, then insert a flat-head screwdriver between the emblem and the hood. Slowly and using light force, it should come right off. Step 2 -- Simply to remove the two grommets left behind sitting in the hood with a pincer, they should pop right out. if you still use the original grommets, you can skip next step. Step 3 -- Push the new grommets onto the mounting pins of new emblem. Step 4 -- Simply press down the emblem with your hand. |
Thanks for posting. I need to do my new CF emblems which have been sitting in my trunk for months.
| All times are GMT -8. The time now is 01:44 AM. |
