How to remove B-pillar trims?
Hi,
I?m sure someone has removed these trims from his/her car and knows how to do it.
Could you please help me? I would like to paint them but I have no idea how to remove
them without breaking anything.
Best regards,
- Tommi
Best regards,
- Tommi
My Ride: G30 M550i
Model Year: 2018
Tommi,
I've looked for the instructions you are asking for two different times on TIS and for the life of me, I can't find them. Hopefully someone else will be able to find it for you (and show me where it was...)
Sorry!
Sorry!
Thanks Rudy.
Still waiting for the info. Anybody who has remove same trims from E39 for example? All kind of information is more than welcome.
Somebody please help me, I would like to paint them to piano black but I haven?t figured out yet how to remove them.
- Tommi
- Tommi
Originally Posted by Harry' post='338715' date='Sep 26 2006, 04:00 PM
There supposed to be some screws so far I?ve heard. In the TIS there?s a manual for that. Take a look under the door seals at the pillar when open the door.
Br,
- Tommi
Front door:
1) Window cavity cover strip on outside of left or right front door.pdf
2) Trim on front door window frame, left or right door window frame, left or right.pdf
Rear door:
1) Removing and installing_replacing window cavity cover strip on rear door on left.pdf
2) Removing and installing_replacing window cavity cover strip on rear door on left.pdf
The little trim part on rear door:
1) Removing and installing left or right rear door trim panel.pdf
2) Housing cover on inner left or right door window frame.pdf
3) Removing and installing_replacing trim for window guide of left or right rear do.pdf
- Antti -
Rear door:
- Antti -
ucsbwsr
26
Feb 26, 2025 08:22 AM
jimmychef
Jul 7, 2015 05:17 PM
