How Do I remove paint splatters?
My Ride: 2004 530i, premium package, sport package, cold weather package, park distance control, heated rear seats, angel ibright v3
The other night while driving home I drove through some spilled paint on the road. Now I have these small paint splatters along my side skirts and inside my mud guards. I tried removing them with a clay bar but they were too stubborn. What should I use? I hear someone say use gasoline or diesel to rub it off? Thanks for the help.
No way I'd use paint thinner on our cars!! ... I'd begin with some WD-40 or Simple Green to see if it softens the paint splatter before moving to a mild clear coat-safe polishing compound. Finishing up with a good wax.
I'd go with a wire brush and a bucket of moist sand. It will be akin to vehicular exfoliation.
My Ride: 07' 550i Black Sapphire Metallic | Sport Package and Premium Package | Nav|Black Dakota Leather | Maple Anthracite Wood | PDC | Comfort Access | Steptronic | Logice 7 | Active Roll Stabilization | Active Steering
WD-40 might do the trick. You can also try a detailing claybar. I've used claybar to remove major overspray from my SUV before. No paint thinner please!! It will either smudge the clear coat or make it dull (depending on what type of clear coat our cars use).
My Ride: 2006 BMW 550i
we took some rags and mineral spirits, and the overspray came off somewhat easy. i'd recommend waxing afterwards.
one other time, my mom was not happy with the light scracthes on my dad's truck bed, so what did she do when he wasnt home one day? she sprayed the bed sides with a spray can, and this truck was only 3 years old. it looked horrible. on that one, i used acetone to remove the spray paint, and you couldnt tell it was ever sprayed. i wouldnt recommend acetone, unless you really need it. its very strong.
over the years i've used gas many times to rub off paint marks from cars either rubbing into other cars, or rubbing into garage door frames.
it sounds crude, but it works.
Looks like I will try WD-40 first. I saw in another post somewhere where they use this product called honda polish which one can buy in a motorcycle shop. What do you guys think about that.
chadillac2000
42
09-13-2017 11:15 AM
545iMike
10-10-2015 08:37 AM
DetailersDomain
Detailing Forum
05-29-2015 04:52 AM
umnitza
03-07-2015 01:53 PM
