hey what's goin on i have hyper white tail light blinker bulbs, also side makers, and HID headlights but the only thing that throws the hole look off is the hole gold blinker part on the side of my headlights does anyone have headlights that are totally clear and if its possible you do how can i get a hold of how to make it happen thanks :)
Unfortunately the only way to do it is by replacing the entire headlight assembly:
http://www.bekkers.com/Merchant2/merchant....ode=bhlight5e60 If you have xenon, it's almost $2000... http://www.bekkers.com/Merchant2/gra...0headlight.jpg |
Short of replacing the entire headlight assembly (very expensive), you can replace the turn signal bulbs with silver coated bulbs that blink amber, which reduce the yellow to a degree, but not entirely--here's some before & after pix:
http://forums.e60.net/index.php?showtopic=7226 |
dammmm well thanks anyway for lookin out
