How to add an aftermarket audio system?
My Ride: 2004 530i, Silver Gray, Premium Pkg, Cold Weather package, Black Leather seats with lumbar support, Poplar wood finish.
Mods: M6 19" wheels with 245/35/19 Front Tires 275/30/19 Rear Tires, K&N Filter, H&R Sway bars, Magnaflow Muffler, Sprint Booster, Black front grill, M-tech front bumper, Debadged
I have an 04' E60 530i with the standard sound system
I am planning to add the Alpine iDA-X001 Digital Media Receiver that will alos hook up my ipod.
Is adding an aftermarket audio system a difficult task...I am assuming it will go in the slot below the climate control.
Have any one done it themselves and can provide inputs?
thanks
thanks
My Ride: F10 535I
Model Year: 2016
Are you planing to remove the factory radio? Are you adding aftermarket amplifiers or using the factory? Changing speakers? Its Definately possible it may just be ALOT of work, are you doing a custom dash?
I dont plan to remove the factory unit. Instead just add the receiver to the slot under the climate control and somehow connect it to the factory stereo so that the iPod connected to the receiver can use the factory sound system. Would liek to do it with as little modification as possible.
My Ride: 2007 BMW E60, Titanium Silver with original BMW Mtec front, aprons, M5 trunk cover, badging, de-chroming, M5 steering wheel, M5 mags BBK JBT 380 mm 6 pot front 355 4 pot rear / Eibach Pro Spring Kit - ICE - Genisis LOC converter, Alpine Multi Media Manager, DLS Ultimate Big 5 amp, Morel Elate 6 front speakers, MB Quart rear speakers, 2 sets SEAS Lotus 10" subs, IPOD interface via Harman Kardon Drive+Play, Critical Mass 10 Farad power capacitor, best of both worlds... Also Bluetooth interface, M5 original sport exhaust, M door sills, and more...
[quote name='vishwen' date='Aug 2 2007, 01:52 AM' post='454068']
You ccc or Mask?
Hi there, you can see what I did, it allowed me to keep all BMW functions and did not modify the dash.
Sound is phenominal. I have changed the AMPs since the layout drawing in the post to be DLS 4 CH + DLS 1200 W Monoblock (the Big 5 was not enough to drive the 2 10" subs.) Lots of pics.
Post link is below.
Hope this helps in some way.
Ted
http://forums.e60.net/index.php?showtopic=39135
You ccc or Mask?
Post link is below.
Ted
zio
06-18-2015 04:42 PM
