Help on Oil Change
Old Dec 2, 2008 | 10:28 PM
Vermillo's Avatar
Is there a DIY on changing the oil on a 2005 530i? This is my first oil change after the free maintenance ran out. I saw a write-up n changing the oil on a 550i, not sure if it applies to a 530i. Also, does everyone typically run only BMW oil and filters? Is there anything comparable that would save me cash?
Old Dec 2, 2008 | 10:42 PM
Gene's Avatar
http://forums.e60.net/index.php?showtopic=49786
The thread is for an LCI 535i
But post #7 addresses differences for his '05 530i and post #55 has a video for an '07 530i oil change (the vid takes some time to load, it's a large file)...
Old Dec 2, 2008 | 11:09 PM
Vermillo's Avatar
Thanks a ton!
Old Dec 3, 2008 | 12:03 AM
cookceramics's Avatar
Vermillo,
Castrol make the oil that BMW use in Autralia. It is a full synthetic 20w-50. Depends on your climate and country. The genuine bmw filter and oil seals are a must. Be very carful when unscrewing the oil cartridge cap with the oil filter tool this can scratch the engine cover. Aparts from that its pretty straight forward and there is a thread in this forum. Do the oil change every 10,00km no longer. I do it every 5,000km
good luck!
JC
coolspot
May 7, 2015 05:50 AM
demosthenesish
May 1, 2015 06:02 AM
Boland01
Apr 6, 2015 10:25 PM
mantraguy
Mar 9, 2015 02:56 AM
Don Juan
Mar 11, 2004 03:14 PM
