Help with Grille Removal
My Ride: 2006 550i...Black/Auburn, Premium Pkg, Comfort Access, Cold Weather Pkg, Active Steering, Heated Rear Seats
I'm attempting to put in the RPI scoop and Im running into a problem with removing the grille. I have read through a few different forums and have the link below that ive been following..
http://raceprecision.com/forums/view...php?f=13&t=119
My problem is with step one... removing the weather striping. I am removing the rubber part with out a problem but it seems like im going to break the plastic part if I keep pushing. is there a different set of instructions for a 550i?? or is this is and im just doing something wrong? thanks for any help
Originally Posted by BlaSTiWi' post='756121' date='Dec 30 2008, 08:00 PM
The guide would be the easiest way, any other way you still have to pull that plastic piece anyway... you can try pushing each of the lock tabs.
Attachment 68136
Attachment 68136
Those tabs are probably what holding when you try to pull so try to push the whole base back and pull up slowly when you can see the edge of the tabs use something to push in to release the edge ...
I just yank it up... I know it's hard to imagine...
Originally Posted by BimmerDC' post='756255' date='Dec 30 2008, 09:20 PM
so i just need to push a little harder? what are the lock tabs? thanks
That is one long piece.
Originally Posted by BimmerDC' post='756290' date='Dec 30 2008, 10:09 PM
can i do just one side at a time? or do i need to do both together? thanks
Originally Posted by Rudy' post='756294' date='Dec 30 2008, 08:16 PM
If you haven't already done so, do a search of these forums -- I seem to remember about a dozen or so threads about removing the grille...
http://forums.e60.net/index.php?showtopic=3622
