Help with adding an AUX cable
Old 01-13-2013, 12:03 AM
sinkMe's Avatar
Be aware of some change in the electronics in preface cars from 09/05. My car is made 11/05 a 2006 model then. Did the same upgrade with aux, but they struggle to get to work properly because there is a slight difference in the cars made before 09/05
Old 01-13-2013, 06:04 AM
ldesouza's Avatar
Thanks for the heads up! What kind of changes did you experience? So far I haven't noticed anything except from a slight hissing sound when I have my phone plugged in but no music playing.
Old 01-16-2013, 11:51 AM
gato911's Avatar
Can someone help me? where can i find a list of codes for my E60. I have an AUX cable that I installed, but its not working since the dealer has to activate it, and they want to charge me around 200euros. I have a bavarian obd cable to imput the codes with
Old 01-16-2013, 09:02 PM
ldesouza's Avatar
Well if this is the first time that youre coding I would recommend doing allot or research and reading. I spent hours reading up on coding before I actually attempted it.
Maybe this will help:
BMW Coding Forum
As for the aux, code the CAPPL module and set AUX_CONFIG to MOUNTED and then add the option to the VO (+NAUX) in the CAS and LMA modules and then program the CCC or M-ASK.
Vman33
03-14-2022 04:43 AM
CHRGRS_BMW
38
09-01-2016 09:39 AM
Wonky
04-12-2016 08:15 PM
bestofthebest
03-28-2016 02:47 PM
Jiawei Zhao
10-21-2015 08:46 PM
Quick Reply: Help with adding an AUX cable
