Hey everyone! I was just wondering if there is a guide out there or if anyone has written a guide on how to replace the e60's battery. My 545i is popping up the battery icon in the mornings when I start it (canadian winter!) and since it's been 4 years I'm thinking of replacing the battery just incase.
Thanks! any help is appreciated! |
There's no guide in replacing the battery. If you are not comfortable in doing it yourself, then let the auto parts store do it for you. If you do it yourself, just make sure the positve cable goes on the pos. terminal. A nd the negative cable goes on the neg. terminal.
Thanks! any help is appreciated! carefull when removing the explosive charge...wldnt want to blow up bimmer :D |
i just replaced mine. i bought mine from a kragen for $89 right after my car wouldn't start (was a sluggish start for a month before).
i wish i took pictures, but here goes for a DIY battery replacement based off memory. 1. Remove the trunk carpet/plastic floor and lift the tray containing the spare. 2. Locate the battery by pulling the rear right corner panel inside of your trunk. There should be 1-2 plastic screws that hold the panel down. 3. Use i believe a 11-13mm socket wrench to unbolt the retainer bar (black) that holds down the battery. 4. Use a 10mm socket wrench to loosen the positive and negative terminal and pull them off the battery. Note that the positive plug has two connections. Only need to loosen the one that is connected to the battery (which is closest to the North edge) 5. Use a Phillips screw driver to loosen the long gray screw on the South side of the battery. This is clipping down the battery on the bottom. 6. Once loose enough, pull the battery straight out. 7. Replace battery and then make sure the metal clip is sitting on top of the edge of the battery case (at the bottom of the battery) 8. Tight screw so battery is held down from the bottom. 9. Attach plugs to Positive and Negative terminals and tighten the nuts. 10. Tighten the retaining bar back on and put the corner panel back. 11. Start your car and let it run for a couple of minutes and drive around the block. Note: i was getting an "increased emission" message after doing this, but i let the car sit over night, and the message hasn't come back. Besides that, the car should start up fine. good luck |
i wish i took pictures, but here goes for a DIY battery replacement based off memory. 1. Remove the trunk carpet/plastic floor and lift the tray containing the spare. 2. Locate the battery by pulling the rear right corner panel inside of your trunk. There should be 1-2 plastic screws that hold the panel down. 3. Use i believe a 11-13mm socket wrench to unbolt the retainer bar (black) that holds down the battery. 4. Use a 10mm socket wrench to loosen the positive and negative terminal and pull them off the battery. Note that the positive plug has two connections. Only need to loosen the one that is connected to the battery (which is closest to the North edge) 5. Use a Phillips screw driver to loosen the long gray screw on the South side of the battery. This is clipping down the battery on the bottom. 6. Once loose enough, pull the battery straight out. 7. Replace battery and then make sure the metal clip is sitting on top of the edge of the battery case (at the bottom of the battery) 8. Tight screw so battery is held down from the bottom. 9. Attach plugs to Positive and Negative terminals and tighten the nuts. 10. Tighten the retaining bar back on and put the corner panel back. 11. Start your car and let it run for a couple of minutes and drive around the block. Note: i was getting an "increased emission" message after doing this, but i let the car sit over night, and the message hasn't come back. Besides that, the car should start up fine. good luck the emmissions error was probably because you forgot about the gas tube that goes with the battery................. |
i'll take a closer look |
Originally Posted by kneemah' post='738616' date='Dec 5 2008, 11:53 AM
there was nothing connected to my original battery, and there was no tube on my new battery. i remember looking at that tube on the old battery, but there was nothing connected to it.
