front right turn signal out
My Ride: 2004 530i Black/ Smoked LED side markers/ CF kidney Grille/ Shadowline Trim/Miro 346 V2/General Exclaim 19"/CF Badges/H&R Sport Springs/ Koni FSD shocks/struts/R1 Concepts Drilled & Slotted Rotors/ Hawk Pads/ Mtec V2 lights/
Do i have to take out the headlight? Any one have any pics of the opening if there is one to change it? Thanks.
Model Year: 2010
Look for the DIY on the angel eye mod. Remove two top black screws with Torx head, loosen two bottom grey screws with hex head (do not remove). The bottom screws are almost hidden, so search with a flash light. Slide out headlamp housing a little (do not need to come all the way out). Loosen signal lamp base (looks like a fin). Replace turn signal lamp.
Just look for the really long piece of plastic sticking out the rear side of the headlight when you pop the hood...lefty-loosie, take it out and replace the bulb. A little iffy to turn, but very possible.
did you check you owner's manual?
if you don't have one, yo can find a pdf version here: https://5series.net/information/
socale39
09-05-2023 08:30 AM
